Bodyworks Voyager: Mission in Anatomy
First post, by Legend789
I checked the compatibility list and I couldn't find Bodyworks Voyager: Mission in Anatomy. I typically use DOSBox-0.63, but I also tried running on DOSBox-0.72. When I save a game, it corrupts the configuration file (This never used to happen.) So I have to configure and when I do, it usually works but once General MIDI didn't work.
The biggest problem is that when I try to restore a saved game. Voyagers says
ERROR wrote:
There isn't enough hard disk space on your installation drive for the save game data file. You must free up at least 4350 bytes on your hard drive before you can save any games.
I have a free space of over 450 GB (I won't say the exact amount as to not give away any information that might endanger the innocent.)
Anybody know how to fix this? It's really imparing. Thanks in advanced!
Reply 2 of 6, by Legend789
Thanks for replying IIGS_User 😀
I'm sorry, but this didn't work = \ I'm not 100% sure why it even says that, but I'm nearly certain that the game's messing up on space-reading. I checked the mount as is and got. 110,540,800 free bytes. With free size on mount, I got 2113,930,240 free bytes (sic: no comma). So obviously free size works 😀 However. It's not the problem that the game has.
Could it be the DOS4GW? I'm not sure but Alien Logic runs on DOS4GW too, but it runs perfectly. Same version also.
I tried executing VOYAGER.EXE with DOS4GW and the restore seems to have worked but the mouse is messed up (moving like crazy).
Reply 4 of 6, by DosFreak
1. Don't hijack someone else's thread.
2. We don't support abandonware here.
3. We don't support abandonware here.
4. WE DON'T SUPPORT ABANDONWARE HERE.
Make your games work offline
Reply 5 of 6, by 1chapelcredit
1. It says next to my name that that was my first post.
2. There's really no reason to be rude about it.
3. You don't have to repeat yourself.
4. You don't have to repeat yourself.
5. YOU REALLY DON'T HAVE TO REPEAT YOURSELF IN CAPS.
6. Don't be a jerk.
