First post, by Mig21
Hi
I used to be able to run Supaplex in dosbox with no trouble. But I haven't played the game for a while and have upgraded both Slackware and Dosbox since then. So I don't know what changed.
Does anyone else here play supaplex in dosbox? Did you have to do anything to fix the jerky scrolling when moving left?
If it works for you, what versions of things do you have?
Thanks
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I think it's fixed in CVS.
2008-06-08 20:27  c2woody
* src/hardware/vga_draw.cpp: adjust line split position (fixes Supaplex)
Try the AEP build: http://cvscompile.aep-emu.de/dosbox.htm
