First post, by Rakor
I spent some time searching the forums but I did not find anything that applied to the problem I am having.
When I enter combat, things go fine for the first 2 turns of combat, then the game crashed to a DOS prompt with the following error:
CMBTSND.LBX [entry 9] exceeds number of LBX entries
This error did not start right away (I am quite a bit into the current game) but now every time I enter combat now, this error occurs.
I am running DOSBox 7.0 and everything else runs just fine.
I am running on a Sony VAIO PCG-K23 laptop (integrated sound by RealTek and integrated video)
Processor: P4 2.8 GHz
Mem: 1 Gig
OS: Windows XP
Anyone have any ideas before I try to re-install MoM?[/b]
Reply 1 of 7, by MiniMax
Rank Moderator
Moderator
Get and install DOSBox 0.72, then we can talk.
_________________
Reply 2 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
although MOM is unfortunately known for the fact that it has some nasty bugs.
you could try with sound off to see if that helps
Water flows down the stream
Reply 7 of 7, by rcblanke
If you haven't already done so, update your game to 1.3.1 with this. I don't know if your savegame is still usable after updating though, be careful.
