First post, by Kudaku Tama
I used the outline to type this and what isn't listed if, it is needed, then inform how to find out what it is.
2. AMD Turion 1.8 Ghrz
3. 1 GB and same as 1
4. ATI mobility Radeon Xpress 200 128MB
6. Windows XP
7. Sei Shojo sentai Lakers 3 (chinese version)
8. No sound whatsoever
10. sound blaster 16
12. dosbox ver. .72
13. tried most things suggested in the readme
Also, because the game itself is hard to locate (if even possible), I will send it to those who want to help at their request.
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 2 of 4, by Kudaku Tama
I did everything your guide said, but still ended up with no sound. I forgot to add this in my first post, but this is a game I downloaded from a random place (though I did make an image of it and placed it on a cd) and if I wanted to use it I just entered the batch file after mounting c: and never installed it, which it did not install when I used your method (I don't even know if what I used was the installer). and what looks to be the apparent sound card execute file, when I try to use it, says
"This sound card I/O is ...0220
This Sound card version is ...0005
Can not found low dma & irq"
Can you infer anything from that? Or would you need the game?
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
Sorry, but when it is something downloaded from a random site, there could be 100 reasons why sound is not working. I suggest you try to find a place to buy the game. Then I am sure it will come with a proper installer.
_________________
Reply 4 of 4, by Kudaku Tama
I realized that but I don't think that there is a proper place to buy the game short of going to Japan or China, and even then its iffy. I downloaded the other prequels to the game from the same place, and this is the only one I'm having any issues with that I can't fix myself. One of the .exe files does come up with
"Successfully installed!
Hot key is ctrl +alt."
but it doesn't seem to do anything.
