Help DOSBox and Fallout
First post, by Alcott
Hi all,
I have a problem with this game. I have installed and patched Fallout and installed DOSBox 0.72.
I start DOSBox with this commands:
1- mount c "c:\Program Files\Interplay\Fallout"
2- c:
3- falloutw.exe
The game dont start, but I receive this message in DOSBox:
this is a Windows NT windowed executable
Any idea? Thanks... 🙁
Reply 1 of 14, by wd
Rank DOSBox Author
DOSBox Author
try fallout.exe (dos) instead of falloutw.exe (windows) keeping in mind you
are using a DOSemulator (DOSbox)
Reply 2 of 14, by Alcott
Ops... I dont have this file in my directory (fallout.exe): only falloutw.exe. Why? Can I try other solution?
Thanks in advance.
A.
Reply 3 of 14, by Freddo
Install the DOS version and not the Windows version.
Reply 4 of 14, by Miki Maus
Have you tried running it directly from Windows?
Windows version of Fallout is pretty stable on Windows XP as I've played it through and didn't experience any problems with it.
Reply 5 of 14, by Alcott
Yes, but I have a black screen in game... 🙁
Reply 6 of 14, by Alcott
Ok... I have uninstalled and reinstalled Fallout (version for DOS this time). In DOSBox (after mount the unit) I have an error when I start the game with command "fallout.exe" 🙁
Could not find the master datafile. Please make sure the FOLLOUT CD is in the drive and that you are running Fallout from directory you installed it to.
EDT: I have tried this command (g:\ is a virtual dvdrom with image of Fallout.iso mounted) but dont work: 🙁
mount d g:\ -t cdrom
DIR command with g work!!!
Reply 7 of 14, by wd
Rank DOSBox Author
DOSBox Author
Try fall.bat
Did you install fallout WITHIN dosbox? It is crucial to do so very often.
Reply 9 of 14, by Alcott
sfall dont help me 🙁
Great program DOSBox... Last problem (I hope). The game is slow (e.g. loading). DOSbox conf:
memsize=64
cycle=auto (but it work at max)
gus=false (to force sound blaster)
The sound is ok, but the game is slow during loading 😢
Thanks!
Reply 10 of 14, by MiniMax
Rank Moderator
Moderator
Try
memsize=32
core=dynamic
cycles=auto
_________________
Reply 11 of 14, by Alcott
Better, but still slow... 🙁
Reply 13 of 14, by MiniMax
Rank Moderator
Moderator
How busy is the CPU when you play? What do the performance graphs in Task Manager show?
_________________
Reply 14 of 14, by stg
alcott can you upload fall.bat for me plz
