First post, by coreyos
Hey all. Just joined here. I downloaded DOS BOX as a way to possibly get Theme Hospital working properly. For a while I was able to get it to work on XP SP2 just by installing and without having to use compatibility mode, but I had to start using compatibility mode due to some freezing issues, and compatibility mode now causes the mouse to lag in game, so I'm trying out DOS BOX. I followed all the directions in the Wiki for mounting and all that good stuff, but when I go to start the EXE in the folder, it tells me the program cannot be run in DOS mode, even though I thought it originally run in DOS? There's another EXE in the main file as well called DOS4GW, which looks like an EXE to get the DOS version running possibly but when I try to run it, I get this:
DOS/4GW fatal error (1004): syntax is DOS4GW <executable.xxx>
However, get this. Just for the hell of it, I mounted the CD ROM as well, and wouldn't you know it, the EXE works on that, and the game seems to run smooth. Now, I would run that, but I can't access my save files if I run it off the CD. Can anyone help me out here?
I also thought of something while posting this. The CD was from Sold Out games and included the latest patch, which I applied when first installing it. I'm thinking that the EXE I ran on the CD was the unpatched version which still will run on DOS and that's why I was able to run it. I suppose I could try reinstalling the base version without the patch, save my save files, and try running the old version with my save files on DOS BOX. I'll let you guys know how that works out.
