First post, by Xeolyte
I've successfully installed DoxBox. I Installed UW1 from floppies and when I tried to run it in dos box said:
underworld can no long run error code D003
Ok ..
I tried the "run it from the cd" method .. (I tried installing from the cd but it always skipped over where do ya wanna put it part.)
mounted the cd fine but when the box comes up where do you want to save games, I get the options saving in F, which is my cdrom drive or Z .. I selected Z and got Error Creating Saved Game Drive.
Don't know if what I’m running on is necessary but in case it is, here it is:
8 GB Memory
Intel core 2 Quad Q6600 2.4GHz CPU
MSI Platinum ATX Intel MB
3-HD 250GB - SATA
Saitek Eclipse II Keyboard
Sapphire Radeon Video Card
2 HP DVD/CD
and yes I DID print out and read the dosbox Readme.
HELP! I really want to play this game again. Thanks!
Xeolyte
Reply 1 of 8, by Xelasarg
If you can't select a c drive, you probably didn't mount it correctly. What are your mounting commands?
"What's a paladin?!"
Reply 5 of 8, by Xeolyte
My C drive is the system drive. The only thing on there is the system and specific programs critical to my line of work. This particular computer was built for video, VR and 3d rendering. All other programs, like games and ones such as Dosbox get relegated to D Drive. I have a C (system), D (non work programs), E (data), F (dvd) G (dvd) H (backup) I (media) and J (client data) drives, sometimes even more at any given time.
I build my computers so HD's can be easily yanked and put into another computer, (gotta love these gaming cases with removable mb trays and easy in/out slots for drives) including the system drive.
After much hair pulling I finally got UW to work .. what I ended up doing was just copied the UW file on the cd to the hd. Discovered Sound Blaster Pro worked with the audio. Regular Sound Blaster didn’t. Got old saves and everything up and running .. now I’m trying to remember if the video resolution was always this bad or if there is some way I can tweak it to make it clearer.
Xeolyte
Reply 6 of 8, by Xeolyte
Forgot to add .. C as a system drive is not an unbreakable rule. Dosbox mounts with no problems what so ever on D. On dual boots sometimes E is a system drive.
Reply 7 of 8, by DosFreak
DosBox doesn't care about your host drives for it's internal drives. It only cares about your host drives when you point to them.
Your command above:
"MOUNT D D:\UW1 AND MOUNT F F:\ -T cdrom "
should be
"Mount c D:\UW1"
"mount d f:\ -t cdrom"
Make your games work offline
Reply 8 of 8, by eL_PuSHeR
Inside DOSBox, drive letters don't need to match REAL drive letters. You can assign a folder on drive H:\ as C:\ drive.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
