First post, by XxArachitexX
Hi, I just discovered DOSBOX. I tried using the method to play "Qbert" from Wikipedia's DOSBOX page, but it didn't work. Does anybody know what I should try/do about this?
XxArachitexX 😢
[thanks in advance]
Reply 1 of 1, by Kippesoep
Give some extra info on what isn't working please. Also, let us know which versions you have.
Finally, Wikipedia's DOSBox page doesn't mention QBert (nor any info on how to get it running). I assume you mean the DOSBox Wiki instead? Which instructions, specifically, are you following?
My site: Ramblings on mostly tech stuff.
