Saving Games
First post, by kturcotte
I'm playing King's Quest IV (Original with typing). How do I save my game? I'm using D-Fend if that helps any.
Will also be playing KQ 5 and 6-would I save my games the same way?
Reply 1 of 25, by DosFreak
Drag mouse cursor to top of screen, click on in-game menu option to save the game.
Make your games work offline
Reply 6 of 25, by kturcotte
All right, I've got it. I've got the game files on both C and D drives (Backup) and setup D-Fend to load the D drive one, while D-Fend and DosBox are both installed on the C drive. Re-ran setup to run the game on the C drive, and it's working now. I take it that was the problem (Running program on different drive than DosBox and D-Fend were installed)?
Thanks for the help!!!
Now how can I make it go full screen?
Reply 8 of 25, by kturcotte
Using DFend reloaded, and that worked, but now I'm back to the original problem. It wants to know where to save files. I did make sure I'm doing everything on the C drive this time.
Also, I'm not getting any in game speech from King's Quest 5 or 6. Is this normal, or is there something I can do about it?
Reply 10 of 25, by kturcotte
wd wrote:
Install the game inside dosbox.
For the sound stuff: configure it correctly using the install.exe or setup.exe
How in the heck do I install the game in DosBox? That's why I'm using a front end 🤣
Reply 12 of 25, by kturcotte
I've done that. I did mange to remap a key so I could use the \ in DosBox. However, it won't let me use Shift, so I can only do a ; instead of a : How do I fix that?
Reply 14 of 25, by kturcotte
It's a US keyboard (I'm in the US).
As far as specs:
Intel Pentium 4 3.6 Ghz with Hyper Threading
2 GBs DDR 3200 RAM
ATI Radeon X700 Pro Video Card (PCI-Express)
Sound Blaster Audigy 2 ZS Platinum Pro Sound Card
Windows Vista Ultimate 32 bit
DosBox 0.72
DFend Reloaded 0.7.0
Reply 17 of 25, by wd
Rank DOSBox Author
DOSBox Author
Remove all remappings (rename/delete mapper.txt) and post EXACTLY
what doesn't work in that state. Also check what happens when you
set usescancodes=false in your dosbox.conf
And all this without any sort of frontend, especially take care that you're
using a default dosbox.conf to start with.
