SimCity 2000
First post, by lonelyswedish
I'm running Dosbox 0.72 with the default .cfg settings
Windows Vista 64-bit, SP 1
AMD Turion X2 Dual-Core Mobile RM-72 2.1 GHz
ATI Radeon HD 3200
I can run other games with no difficulty -- warcraft 2, dune 2, the incredible machine. When I try to load SimCity 2000 in Dosbox, however, it gives me the following message:
The video card you have selected is not found
please re-install, and verify that your video card is supported
This is in the dos-interface of dosbox, it doesn't even load up the game at all.
Any clue how to fix it?
Reply 2 of 3, by MiniMax
Rank Moderator
Moderator
Que?
_________________
Reply 3 of 3, by boyofdestiny
Here are my settings, works a treat (DOSBox 0.72 on Ubuntu 9.04)
    64.6 KiB
    324 downloads
    setup
    208.04 KiB
    336 downloads
    title
