First post, by Bezoz
Hi,
I want to get Wolfenstein 3D to run on DosBox but doesn't seem like it will.
I installed Wolf3D (entire folder) in a folder I called c:\oldgames
I also mounted c:\oldgames as the c:\
Now in my DosBox the prompt is
c:\Wolf3d>
The execute file of Wolf3D is wolf3d.exe
So by right, this line should work:
c:\wolf3d>wolf3d.exe
And yet it does not work.
Can anyone tell me what is wrong?
And also, how do I exit DosBox properly? Just X it?
Thanks for any answers.
Reply 2 of 11, by MiniMax
Rank Moderator
Moderator
I think that is where you screwed up.
_________________
Reply 3 of 11, by Bezoz
I installed the wolfenstein folder in a folder I called oldgames
Inside c:\oldgames\wolf3d\
there is the execute file named wolf3d.exe
So my steps were like below:
1) z:\>mount c c:\oldgames
2) z:\>c:\
3) c:\>cd wolf3d
4) C:\wolf3d>wolf3d.exe
These are the paths I used or what happened, can you spot what went wrong? The game doesn't load.
Reply 8 of 11, by Bezoz
did you install the game using dosbox as well ?
No, I just downloaded the zip file from a download site and extracted the files into a folder named wolf3d. It's a very small game with a few files and there is an execute file called wolf3d.exe
Reply 9 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
well I don't know. I know the version that you have to install works fine.
Maybe ask where you downloaded it.
Water flows down the stream
Reply 10 of 11, by MiniMax
Rank Moderator
Moderator
The attached config file will install and run Wolfenstein 3D (Shareware v. 1.4). Just unpack the 1wolf14.zip file into a folder called Unpacked, create an empty folder called C-drive, and run DOSBox from the folder with the Unpacked and the C-drive folder.
    dosbox.conf
    2.06 KiB
    392 downloads
    DOSBox 0.72 config file for Wolfenstein 3D (Shareware v. 1.4)
_________________
Reply 11 of 11, by Bezoz
Thanks. I'll try that.
