First post, by Poggle
I do hope this in the correct area! Ok, I have the star wasr X-wing collectors CD again and wish to start playing the game once more, I only ever did play this one game when it came out. My OS is XP and it will not run the CD/game. Dosbox was downloaded and installed, I followed the tutorial to the letter re using Dosbox to load the game and play it, I cannot get the game to load. All I get is "Cannot find X-WING CD" coming up. Any clues anyone?
John
Reply 1 of 16, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
describe precisely what you did to get this far, precisely means especially your mountings and so on.
Also see the 60 seconds guide, follow that and if you fail, tell us again, what you did.
60 seconds guide to getting your game to run in DOSBox
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 16, by Poggle
I will cut and paste from the tutorial on the Dosbox web site.
Now, the hardest part, getting games to run. First, run dosbox.exe in your DOSBox folder. Remember that OLDGAMES directory you created in Step 1? You have to basically set that as new directory just for DOSBox. Essentially, it's going to become the C:\> drive of DOSBox. So, type:
Z:\>MOUNT C C:\OLDGAMES
Drive C mounted as local directory C:\OLDGAMES\
To dissect the above:
MOUNT: Tells the program to mount a directory
C: Tells the program what you want your new drive to be called (leaving it as C: is fine)
C:\OLDGAMES: This is the directory I want to set as the new drive for DOSBox, because all my games are in it. If you created a different directory, write in the directory you created.
(Note: If you want to mount a CD-ROM instead of a folder, type this:
Z:\>MOUNT D D:\ -t cdrom
MSCDEX installed.
Drive D is mounted as CDRom D:\
(Note: "cdrom" is case sensitive and must be lowercase!)
In this example, D:\ -T cdrom tells DOSBox that my D:\ drive is a CD-ROM drive, and the first D, tells DOSBox what my new drive name should be called. If you are running your game off a CD-ROM then make sure to use D: in place of C: in the following examples. You can find instructions on how to mount other devices, such as floppy drives, in the mount section).
After you've done this, you will be prompted with a Z:\>. Now, just write what you wanted to call your new DOSBox drive, which as I said above, we called C. To navigate to that newly mounted drive just type in:
Z:\>C:
C:\>
Hopefully, you're all set! Now, it's time to run the game. Previously I had mentioned a game called TESTDRIV in my OLDGAMES folder. I now want DOSBox to go to that folder. So type in:
C:\>CD TESTDRIV
C:\TESTDRIV>
It is at this point that I get the message regarding not finding X-WING CD
John
Reply 3 of 16, by Dominus
DOSBox Moderator
Go with the 60 seconds guide. The tutorial will not help you far, since it doesn't help you installing from CD-Roms. The 60s guide does that.
Reply 5 of 16, by Poggle
Well, well, well............According to MY computer, I have no Documents etc!!!!! I do MOUNT C C:\Documents and Settings\John\My Documents\DOSBox\X-Wing and I get told that Documents do not exist...........Good that is!
John
Reply 6 of 16, by Poggle
And my thanks to the Mod who kindly moved the Posts and showed me the error of my ways:)
I should spend lots more time reading the how to post section before blundering in like the newbie I am:)
John
Reply 7 of 16, by Kippesoep
That's correct. There is no folder C:\Documents. What you want is the following (note the quotes):
MOUNT C "C:\Documents and Settings\John\My Documents\DOSBox\X-Wing"
Reply 9 of 16, by Poggle
Thank you so very, very much for your wonderful help chaps. The game is working now, albeit on a small screen rather than a full screen BUT, it WORKS!!! Now just to sort out what to do so I do not have to go through all the palaver again then next time I want to play it!!
John
Reply 12 of 16, by MiniMax
Rank Moderator
Moderator
Start -> Programs -> DOSBox 0.73 -> Configuration -> Edit configuration
_________________
Reply 13 of 16, by ripa
In the dosbox config, change fullresolution=original to fullresolution=0x0, output=surface to output=ddraw (or opengl, openglnb or overlay) and change aspect=false to aspect=true.
Reply 14 of 16, by Poggle
Thank you all so very much once more for your time and patience with me. All is sorted out now. I found the ALT/ENTER line Ripa, and now have full screen when playing the game. I still need to type a liine when first firing up but that is nothing, only a few seconds.
John
