First post, by Deadsayer
I'm trying to install this old top down shooter. I'm sure at least some of you have heard of it. The problem is, it says there's not enough disk space on the drive I'm installing it on. There is, of course, way more space that it requires.
I realize there is a thread about "Game X doesn't work" yadda yadda and there is a part in that thread about a smiliar issue. That, however, is referring to memory, not disk space. Regardless, I've tried the Loadfix command and it doesn't seem to make any difference.
My mount commands, which I've added to the autoexec portion of the dosbox.conf file, are thus:
mount d e:\ -t cdrom
mount c d:\
Everything else is default except for some screen resolution settings.
Thanks.
