Daggerfall Wont Install
First post, by morgwin
Hi.
When i now try to install elder scrolls daggerfall with the latest dosbox i get a error about not having enough disk space before that started happening the game would install but i couldnt find it on hard disk other times it says i need the cd.
I have admin rights.
I am using windows 7
Thanks.
morgwin
Reply 3 of 40, by MiniMax
Rank Moderator
Moderator
You are lying.
_________________
Reply 5 of 40, by MiniMax
Rank Moderator
Moderator
Let's start checking. Item no. 2 in the instructions:
2) After DOSBox is installed, navigate to its entry in the Start Menu (DOSBox-0.73) and then select “Configuration,” and then “Edit Configuration.” If you have used DOSBox before, it may be best to run “Reset Configuration” first before running “Edit Configuration.”
You did that? Used DOSBox version 0.73?
_________________
Reply 7 of 40, by MiniMax
Rank Moderator
Moderator
Do you have the new freely downloadable version from Bethsoft.com, or do you have a retail version on CD?
If you have the download version, where did you unzip it?
_________________
Reply 9 of 40, by Qbix
Rank DOSBox Author
DOSBox Author
not enough space: forgot/mistake in -freesize parameter
no cd: mistake in mounting the cdrom with the right label.
Water flows down the stream
Reply 12 of 40, by MiniMax
Rank Moderator
Moderator
Could this cause a problem with reading the label?
_________________
Reply 13 of 40, by Freddo
Lots of people seem to get a "ERROR: Looks like you have inserted the wrong CD. Please insert your Daggerfall CD in your CD rom and try again." message. I'm not sure what the cause of it is, seem to happen to people on both Windows and OSX.
I would like to know what these people type wrong, if they type anything wrong or if DOSBox is to blame, but that seems unlikely since it works for so many others.
It is possible to bypass the disc check though, which was also needed to get Daggerfall to run on older versions of DOSBox, but that's not really solving the issue. Just walking around it.
Reply 14 of 40, by HunterZ
I'm using DOSBox in Windows 7 to run the free Daggerfall release via Bethesda's instructions and it works fine. Make absolutely sure you're mounting the directory as a CD the exact same way each time your run DOSBox (I put it on the autoexec section of my dosbox.conf to save hassle). It's especially imperative that you specify the "-t cdrom -label Daggerfall" parameters to the mount command, with the label having that exact capitalization.
Reply 15 of 40, by MiniMax
Rank Moderator
Moderator
HunterZ, you are 100% correct. But that can not be the explanation here, because:
morgwin wrote:
I just did the intructions word for word but it still asks for a cd
_________________
Reply 16 of 40, by Miki Maus
We can't know that with certainty without having OP post screenshot of DOSBox window with exact commands typed in and executed.
