First post, by Hater Depot
When I play Syndicate Wars and Ascendancy in DOSBox a thin strip of the top and bottom portions of the screen is cut off. I have an LCD monitor and tried fixing it by using scaler2x but not sure if I used it correctly because the problem remained. (I've followed discussions here about scalers and LCD screens but not understood them.) I'm thinking that I only see the problem with these games because all others I play are VGA not SVGA. Any ideas?
Reply 2 of 4, by ripa
dosbox config:
fullresolution=0x0
output=ddraw #or opengl, openglnb, or overlay
aspect=true
edit - explanation:
The fullresolution line sets dosbox to use your desktop resolution (which most probably is the right one to use with your monitor). The output line enables hardware scaling so dosbox stretches the game (from 320x200 pixels or whatever) to fit the screen (with output=surface, dosbox adds black bars instead of stretching). Aspect line makes sure the game has correct proportions (not too skinny or fat graphics).
