First post, by TeaRex
I can't seem to find a cpu speed setting where the lip synch in the Ultima VII intro is correct without the game proper being much too fast to use.
I use 0.73 on Windows XP home SP3. Machine is a Aspire One netbook, Intel Atom processor @ 1.6 GHz, 1 GB of RAM. No frontend is used, I prefer to edit the configuration directly. Complete .conf is attached.
At cycles=max the lip synch works, but the sound stutters a bit (even with large prebuffer values) and of course the game runs too fast, NPCs zip around like they've had several bars of that Nazi Pilot Chocolate.
At a playable cycles=9000 or so, the lip synch is completely messed up, the speech finishes long before the guardian animation stops moving its mouth.
Any ideas?
    ULTIMA7.CONF
    9.98 KiB
    163 downloads
    Config used.
tearex
Reply 2 of 7, by MiniMax
Rank Moderator
Moderator
Maybe
cycles=max 80%
(which will leave CPU cycles to do the sound emulation)
_________________
Reply 3 of 7, by TeaRex
robertmo, thanks but I'm already using the dynamic core, and adding more cycles makes the game too fast, as I wrote.
MiniMax, I tried your suggestion, also with lower numbers. The result was the same as for plain cycles=max: stuttering in the intro and a game that runs too fast to be playable.
I also tried using the normal core -- without success.
Thank you two anyway for your help.
tearex
Reply 4 of 7, by HunterZ
You mentioned trying a larger prebuffer, but have you tried increasing the blocksize= setting?
You might also try messing with the video settings in case it's an issue for the video hardware being too weak. Try fullresolution=original (I think) and scaler=none, and try different output= settings with it.
Reply 5 of 7, by ADDiCT
Let me throw a theory into the discussion. I don't know the game, but what if the "synching" is just a figment of imagination? I can remember only a handful of DOS games that had more or less good synching (LucasArts adventures come to mind). I mean, many DOS machines had a hard time playing videos at all, not to speak of perfectly synchronizing video to audio on a multitude of possible hw/memory configs, without some sort of common API.
EDIT: ah, i've missed an important part of the original post. My theory could explain a small a/v discrepancy, not what the op has described.
Reply 6 of 7, by TeaRex
I've found the culprit. It was fulldouble=true.
With fulldouble=false, things work very well.
Howver, in the course of experimenting, I found a couple of strangenesses:
fulldouble doesn't seem to be compatible with output=surface. The screen was very messed up.
Only output=ddraw will scale up machine=vgaonly mode 13h output to 800x600 with aspect=true and scaler=none. The other hardware-accelerated output= options will leave a black border, seemingly using 640x480 only. This behaviour disappears with machine=svga_s3.
The ddraw scaled output looks much better (less mushy) with machine=vgaonly than with machine=svga_s3.
In short, there seem to be a bunch of strange interactions between the various options.
tearex
