First post, by MasterGrazzt
Hi, I'm trying to play this game but unfortunately, I get the strangest error I've ever encountered with DOSBox.
I successfully manage to install the game but when I start it, I get a flashing DOSBox screen. The music and sound is playing, but the graphics are not showing. Basically the DOS text is flashing and cycling colours.
I have an Intel Core 2 at 4.4 ghz, 2 gigs of RAM and a GeForce 9400 GT. I'm using an LCD monitor if that makes any sort of difference.
I'm using D-Fend Reloaded with DOSBox 0.73. I have the basic configuration it uses for all games for it right now, I only added my DVD drive.
Thanks in advance.
PS: Silly me, I forgot to mention that I'm using Windows XP Professional with Service Pack 3. Also, if any of you feel that any information is missing please ask.
Reply 1 of 2, by Neville
Have you tried the new machine options? Specifically, setting DOSBox to vgaonly (if the game supports VGA mode), vesa_nolfb or vesa_oldvbe could produce different results.
Reply 2 of 2, by MasterGrazzt
Hey, thanks for the advice. I changed the resolution choice to 640x480 and the graphics option to SVGA_et4000 and it works! Consider this problem solved.
