First post, by hawkwindeb
1st time users of DOSBox 0.73 on Windows XP SP3
I have searched and found 3 posts, tried their suggestions and still no joy.
Problems running Future Magic - Sentinel Worlds
Sentinel Worlds ?
Willy Beamish - Unable to install or play
The sad thing is I own the original, disks manual, even the clue book - everything - but a 5 1/4 disk drive for the floppies that came with the game will not work on my new PC. So, I found and downloaded the game from:
Qbix: No link to abandonware please
The person that gave it to them has modified it somehow but their bat file and instructions do not work. Seems to be looking for some drive or dir that does not exist. After following their instructions, I tried the following things.
- Renamed the dir's from FM to FMPLAY and D to FMDAT, then tried each of the following:
- Mounting as C: so DOSBox C: prompt sees FMPLAY and FMDAT dir's
- Mounted FMPLAY as A: and FMDAT as B:
- Mounted FMPLAY as C: (ie: SENTINEL.EXE would be in C's root)
- Copied entire contents of both dirs into a single dir and mounted that as A: and then as C: (ie: SENTINEL.EXE would be in C's root)
Its looking for the game not data disk so its running the game but not getting very far.
Interestingly if Mounting as C: so DOSBox C: prompt sees FMPLAY and FMDAT dir's, and type \FMPLAY\SENTINEL.EXE at the C: prompt I get a flashing cursor for ever or at least 10 min's when I kill DOSBox.
Even tried D-Fend Reloaded as a front end with all the above as well as editing the DOSBox config as in all the above tries, same results.
So, before I go and purchase a USB 5 1/4 floppy disk drive and run the installation for a HD, is there a way for DOSBox or other means to see what SENTINEL.EXE is looking for?
I'll email someone that wants to test the sentinel_worlds.zip I downloaded from them if you don't want to go through the links and reg at other sites they make you do for download credits.
