Lurid Land
First post, by LLAND
So, i created directory vanhatpelit/Lurideng/ and opened dosbox(0.73)
mount c c:\vanhatpelit
mount d d:/ -t cdrom it say MSCDEX: Mounted subdirectory:limited support
d:/run
d:\cd lurideng
d:\install install completed
c:\games\lurid
c:\games\lurid\lland or dos4gw not sure which is right
DOS4GW gives me this:
DOS/4GW projected mode run-time version 1.97
copyright (c) rational systems, inc . 1990-1994
DOS/4GW fatal error (1004): syntax error DOS4GW <excutable>
and LLAND:
ERROR: Unable to find data files.
Please check if path to cd-rom drive is valid,
or re-install game, if cd-rom drive(s) changed.
current path to data files: "c:\"
Where did i go wrong?
Reply 1 of 12, by DosFreak
Did you mount your cd?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 4 of 12, by LLAND
I edited answer to original post.
Okay this might be cause of the problem, because i didnt really understanded this. So i downloaded this game and burned the games folder to cd. I am not sure if that was nessesary thing to do, because i had the game already on my computer .
sry my english 😀
Reply 5 of 12, by wd
Rank DOSBox Author
DOSBox Author
Create an empty directory on your physical c-drive, mount that as c in dosbox.
Mount your cdrom as you did above, then install the game.
Please post the EXACT steps you perform, including the response of dosbox.
Right before starting the installer take a screenshot and append that to your
posting if there are problems.
Do the same when starting the game.
Reply 6 of 12, by LLAND
http://img132.imageshack.us/img132/3435/luridasennus.png
Previously i mounted c for lurideng folder now i created empty folder vanhatpelit2 like you said and there is not limited support problem anymore.
http://img171.imageshack.us/img171/2279/luridasennus2.png
Reply 11 of 12, by wd
Rank DOSBox Author
DOSBox Author
I happen to have the original/full english one with me, so I believe that sharing it here will be ok.
No it's not unless you happen to be the copyright holder. Otherwise remove the links.
