First post, by cheve
Hi,
I have trouble starting the bible reader by running the normal startup .bat file at the command line.
I am getting 'Use MM Batch file to Run the Bible' whenever I tried to launch the bible at the command prompt.
FWIW, I am able to run the bible reader in the DOS windows of my WinXP computer.
Suggestion to troubleshoot it is appreciated. Thank you,
Cheers
Reply 1 of 1, by DosFreak
Post the contents of the .bat
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
