First post, by drraypalmer
Hello,
I'm trying to run Colonization 3.0 in DOSBox 0.73 in Mac OSX 10.6.2, and it crashes every time just as it finishes loading a new game and gets to the map screen. I tried running with no sound configured in the game, no luck. I also tried core=dynamic, simple, and normal, and none made a difference. However, the same setup works fine in my WinXP virtual machine running DOSBox, but then I'm stuck with an emulator inside a VM. Any suggestions?
