First post, by rdeniseq
Hello!
I'm trying to install The 7th Guest on my laptop and I somehow managed to get through the DosBox and got it to begin uploading and installing the 7th guest. The installation goes seemingly well for about 10 seconds and gets stuck on the "xmi.rl" file. Any clues as to what might be causing this? I've tried to restart, I've tried deleting the files it had already copied and then I restarted the installation process but it always gets stuck on the same file. Any help would be much appreciated! Thank you in advance!
