First post, by roland1968
Hi all,
I have a scroll problem at The Perfect General 1. If playing a scenario which map is bigger than the scenario window and I scroll down and
then I scroll up, the text line over the scenario window will be copied above the whole scenario window (see the attached screenshot).
I use dosbox 0.74 and I've tried all options for resolutions and VGA-Cards.
Additional infos:
CPU: AMD Athlon II 250
Graphic adapter: MSI R4350-MD512H
OS: XP with SP3
dosbox: 0.74
Best regards
Roland
