First post, by Nytegard
Using the Complete Ultima 7 CD version.
When playing the game, the audio will cut off in the intro after the Guardian starts to say "Avatar, know that ..."
Unfortunately, I can't install the game inside nor outside of DOSBox. I'm using Win 7 64 Bit, so it won't run 16 bit code, and when I try installing it inside DOSBox, everything goes well until it reaches the choose your audio section, at which point it claims the installation failed, and immediately exits out.
I generated the config file through installing Serpent Isle (and copying it over), and Serpent Isle plays just fine, but The Black Gate doesn't.
Just to make sure, I installed the game with my CD on a 486, and everything worked perfectly, but I didn't remember to copy the config file before I placed it back in storage.
