First post, by Myloch
- Oldbie
Rally Championships (cdrom edition) error message
My system: centrino2 dual core 2ghz, geforce 9600m gt, vista 32bit, 4gb ram, Idt high def audio codec (soundcard), HL-DT-ST DVDRAM GSA-T50L. Using dosbox 0.74 with default config settings.
I mounted the cdrom using mount d f:\ (my real disc drive letter) -label cdname -ioctl_mci, hard drive drive: mount c c:\gamestoragedirectory
If I try to start the game directly from cdrom I receive an obscure error message: Runtime error 100 at 0000:0089 and then the application hangs, it does not return to dos prompt but the classic dos symbol "_" is blinking.
the game has got a start.bat file to be executed, here is the bat content:
@ECHO OFF
POSIX
RACECD
If I directly execute posix.exe it give the runtime error but it returns to dos If I use racecd.exe it hangs with blinking "_" (and not return to prompt)
If I use install program go.exe (as the game manual suggested),
I got a "runtime error 002 at 0000:17C8" after selecting soundcard (sb16 220 7 1), processor (the faster that is available, a pentium 90) and install directory. It returns to dos prompt (again no crash in dosbox) and it does NOT install.
Tested and working under real dos environment on a legacy pc.
Situation at 10.10.2010: tried with different cdrom mount settings, different output settings. still no luck.
