Rayman 1 no music in DosBox
First post, by Trevtsr
When i play rayman in DosBox all i get is the sounds i cant get the the music working and rayman is not the same without the music.And i think the music is included but im not for sure it has a music folder and it has files that say RAY1.lev and so on.
Reply 7 of 11, by Mau1wurf1977
Check the readme or google about DOSBox and how it plays CD Audio tracks!
Or use D-Fend reloaded, which is a frontend and a lot easier to use (no command lines).
My YouTube channel
Reply 8 of 11, by Gamecollector
Well, Rayman cd have 25 CDA tracks, so - you just need to play with cd in drive.
"mount d l:\ -t cdrom" do the trick for me. L - my real dvd-drive letter.
Reply 11 of 11, by DaniX
hi, I had the same problem, but i got rayman's music to work!!
in my case in using cd rom but its not really metter.
follow my steps:
1. mount your .iso file.
2. create a foulder called "oldgames" in your hard drive (c:\)
3. open DOSBOX and type:
mount c c:\oldgames
4. type: mount d z:\ -t cdrom -ioctl_dx
when the Z is the letter of your mounted iso file. and just so you know that the _DX adds your audio works/
5. type: D:\
6. type: install
7. your install should open, change your soundcart to soundblaster or soundblaster 16 and install the game.
8. now when you play the music should work!!!
sorry for my english if there is any mistakes...good luck!
notify me if it worked
