keyboard jamming
First post, by 123kid
hi guys
ive recently discovered dosbox and immediately set forth to play the old games i had as a kid..such as commander keen, duke nukem, captain comic, ddm soccer 96, etc
but im having a major issue with my keyboard which ruins the gameplay
lets say im playing soccer and im running diagonally and want to turn back
id have to release the keys completely to move down
i dont have this problem with any windows games or in any other applications, so this problem is specific to dosbox
is there anything that can be done?
Reply 1 of 16, by garrynichol
Just use the keymap function to make the keys do what you want.
Reply 2 of 16, by leileilol
alternatively, you can get a different keyboard.
This isn't a DOSBox problem, it's a "they don't make them like they used to" problem.
long live PCem
FUCK "AI"
Reply 3 of 16, by 123kid
well that is unfortunate..
gamepads arent quite as good as the good ol' keyboard
Reply 4 of 16, by bloodbat
You could also invest in a fancy keyboard...
Reply 5 of 16, by 123kid
im still not sure how this is a keyboard problem
i can hold all directional keys to my hearts content in something like crysis, etc
but in dosbox i have to take my fingers completely off the keys to use the next one, which really kills the experience
Reply 6 of 16, by wd
Rank DOSBox Author
DOSBox Author
Yeah strange.
Reply 7 of 16, by 123kid
im detecting a little sarcasm? from a dosbox author nonetheless
reason being - this issue only occurs in dosbox, not in other games as previously mentioned
Reply 8 of 16, by wd
Rank DOSBox Author
DOSBox Author
There's no sarcasm. It's a strange problem you have, and all possible solutions have already been posted.
Reply 9 of 16, by bloodbat
All directional keys in Crysis as in WASD vs the arrow up, down, etc?
Reply 10 of 16, by VileR
you could try playing with the cycles (increasing them by a lot)... seems to have helped someone else who had a problem of keyboard events not registering properly. Not the same problem, but it might be related.
Reply 11 of 16, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Depends a lot on how a particular game reads the keyboard. If there is an issue, it's possible that it's in SDL, not in DOSBox itself, so you could try other emulators that use SDL. Could also try SET SDL_VIDEODRIVER=WINDIB, which might seem more about video than the keyboard, but I believe it forces SDL to not use DirectX for other things, such as DirectInput.
Reply 12 of 16, by 123kid
yes
Reply 13 of 16, by bloodbat
123kid wrote:
yes
Yes what? Anyway, I have a Sidewinder keyboard, it is claimed you can press n keys simultaneously with it, it's partially true...when using WASD, if I use the arrows, they won't register properly if paired with...say...shift. I don't really get the need for pressing, say, up and down at the same time, after all, you can't go forward and backward at the same time (you'd come to standstill), nor can you traverse two diagonals at once; given that, Crysis might get the jammed keyboard too, you're just not noticing or your keyboard could be wired like mine and work with WASD but not the arrows (that seem to have gone out of style for such endeavors)
Reply 14 of 16, by 123kid
a mechanical keyboard should alleviate these problems as the circuit for keys are independent of one another, therefore wont jam on multiple key presses/holds in the same area
(i use arrows and WASD area for dosbox)
Reply 15 of 16, by garrynichol
In some cases you may have to re-map the keyboard to suit your needs. I did and evrything works fine now except I have to remember I swapped a couple of keys. Try what ripsaw8080 wrote first.
Reply 16 of 16, by robertmo
old keyboards were optimised for a use of arrows and ctrl/alt/shift/space and were jamming with asdw with ctrl/alt/shift/space.
as modern games use asdw with ctrl/alt/shift/space so in order to gain no jamming this combinations they had to jamm arrows with ctrl/alt/shift/space i guess
