First post, by mrgapo
Hi, I am using old accounting software running in dos. I've installed the software succesfully. But when I tried to print it i print out just few characters (same result if I try print to file)
In console I get this:
PRINTER: Skipping unsupported command ESC ( 1 (231).
60085589: FILES:Special file open command 42 file c:\BOZIC11\PARTNER.BS
PRINTER: Skipping unsupported command ESC ( s (273).
61141489: FILES:Special file open command 42 file c:\BOZIC11\KLAVZUL.BS
61399302: FILES:Special file open command 42 file c:\BOZIC11\POSTRAC.FKT
Does anybody have the same problem or know the solution.
Thanks
Reply 2 of 2, by sliderider
Qbix wrote:
use an emulator that isn't target at games.
What he said. DOSBox is not a complete implementation of DOS, just enough to get a lot of games to run. You need an emulator with more complete DOS support than DOSBox provides for non-game applications. Some apps might run, but since they aren't officially supported tech support is not generally provided for them.
