Can't Run Install.exe To Install Game.
First post, by Shmaesh
Ok. So I'm a 90's kid. Taught myself to use DOSBox (not super well, mind you) so I could play SimAnt and Oregon Trail (my purchased version of the latter junked out when I upgraded to a 64-bit version of 7).
While I was downloading nostalgia games, I downloaded SimEarth.
I have successfully run SimAnt and feel confident in my ability to follow a Wiki (my success is owed entirely to that) to accomplish things.
When I try to run install.exe for SimEarth, my only options are from drives A or B.
After I select one, I'm offered C through H as destination drives.
When any of them is selected, it returns an error that the drive doesn't have enough room.
How do I get around this? Can I change the options for install destinations? Or redefine them? I had originally mounted the games folder as an A drive, but it didn't seem to make a difference.
I understand that the software I'm working with is not supported, probably. However, my question does center around DOSbox, so any help would be super appreciated.
Thanks!
