First post, by irvoke
Hi,
I'm running above mentioned game on DosBox 0.74 and I'm experiencing weird popping sounds in the beginning of some sound effects, especially when using a weapon. There's a video on youtube here http://www.youtube.com/watch?v=pxSbetnaD0A where a guy complains about the same very thing and you can hear the popping in the video to get an idea what it sounds like. I tried using more CPU cycles and it got rid of most audio lag / distortion problems but the popping sound remained. Is this perhaps a game specific problem or perhaps something that can be affected by changing DosBox's settings? Thanks in advance.
Here's the system jazz:
OS: Windows 7 Professoinal 64-bit
CPU: Intel Core i7 3930K (6 cores @ 3,2Ghz)
RAM: 8GB DDR3 1600Mhz CL9
GPU: Radeon HD 6950 2GB
MB: Asus P9X79
DosBox version 0.74
Elder Scrolls Arena (CD) version 1.07
I'm not sure what the video and audio mode required in the posting instructions mean but here's what's in the config file I hope it tells you enough information
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=22050
language=
machine=svga_s3
captures=capture
memsize=32
Reply 1 of 8, by irvoke
Now that I've played the game a bit more, I'd like to add more information: Whenever a text box appears announcing something, wheter it be "you have rested" or "you've gained a level" or anything, the game slows down like heck. With this I also tried adding more CPU cycles to make the game run smoother, but it didn't work. Everything runs smoothly except the weapon sound effect and all sounds produced during a text box appearance. I read online that using too much CPU cycles could cause stuttering audio, but whenever I try to lower the cycles the game just slows down into unplayable speed and it doesn't effect the audio stuttering and pops at all.
Reply 2 of 8, by DosFreak
Try changing the soundcard configuration for the game to Soundblaster Pro.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 3 of 8, by irvoke
Tried changing sb16 to sbpro1 and it got rid of most of pops and clicks but the weapon sound effect popping (both me hitting and the enemies aswell) still remained. Makes me wonder if it's something actually in the game sound files. I can't seem to get rid of it. Good news is that I found out what was causing the audio lag pops with the text boxes: In [sdl] I changed output=surface to output=opengl and it got rid of all the lag and lag-caused audio problems. Now the game runs smooth as butter.
Reply 4 of 8, by kolano
One other thing to check is that you haven't re-aligned the general Mixer rate, by setting something like...
[mixer]
rate=96000
...I had noticed that doing so causes clicking in some games, likely related to 96000 not being an even multiple of 44100/22050.
This question likely belongs elsewhere, but would setting it to an even multiple (i.e. 98200) work/correct for the clicking/popping I was hearing?
Eyecandy: Turn your computer into an expensive lava lamp.
Reply 5 of 8, by Stingm
This may not be the answer you want but it works. There is a preconfigured arena cd and dosbox 074 at uesp.net and it doesn't have that problem. There is also a guide to running area with dosbox on newer computers. Hope this helps!
Sting
Reply 6 of 8, by irvoke
One other thing to check is that you haven't re-aligned the general Mixer rate, by setting something like... […]
[mixer]
rate=96000
Nope, didn't touch the mixer settings. It's at 22050 Hz. Here's what's in the
config file
nosound=false
rate=22050
blocksize=2048
prebuffer=10
That reminds me: does blocksize or prebuffer affect this kind of things? I tried playing around with those just for the heck of it but it just ended up screwing up the game so that it became uplayable. =P
Reply 7 of 8, by irvoke
I am, actually, using the (most likely) very same version you are talking about, Stigm. The one I have is the CD version 1.07 that has a proper windows installer and comes with a preconfigured DosBox version 0.74, which is what I'm using the play this game. Here's the link where I downloaded this http://theelderscrolls.wiwiland.net/?title=Ar … :_ArenaSetup_EN.
Reply 8 of 8, by Stingm
Yeah looks to be the same one I got just at another site. I unfortunately have no idea why your having the problem. Must be computer specific. I hope one of the experts here can help you.
Sting
