MasterGrazzt wrote:my Win 7 installation is screwed. After using it for a bit, the screen flashed blue, the computer rebooted, and the BIOS loads in an infinite loop, and can't detect the HD. What's more, if I try to use my recovery disc to reinstall Windows, it just displays two small partitions (one 10.6 gigs, one 4.3 gigs) that it cannot install Windows on. Help!
Btw I am on a Samsung laptop, using the Samsung recovery disc. I'm not surexwhat the motherboard is, but it is a Phoenix BIOS. I'm not sure about most of the stats. I apologize for the short post but I'm using a Galaxy pad to type this.
DosBox didn't do this.
Here's what I'd do:
-If the recovery disk includes a recovery console boot into it and see if the Windows partition is recognized, try fixmbr and fixboot. If that fails...
-I'd boot into Ubuntu's live CD Disk Utility and check S.M.A.R.T status. If status reports everything's fine then...
-I'm not really familiar with Samsung recovery disks, but if they boot into Windows setup, check the type of both partitions (are they NTFS, FAT32, FAT16, something else?) if you can delete both partitions and create a fresh one with all available space. If this fails...
-If I'm comfortable opening the laptop I'd do so and check the HDD connection for firmness (it probably includes a "socket" thingie over the HDD connector, check that first). If I'm not, I'd take it to a service center.
-If it's not a connection problem, it sounds like a faulty hard drive (BIOS should be able to detect it, disregarding the partitions): maybe the hard drive got banged (did you drop the laptop?); maybe it overheated and decided to commit suicide; maybe it ran its useful life; maybe you just had bad luck (not DosBox related, though) sometimes hard drives just die.
It would have been swell if you copied some information from that BSOD to check what caused it (the error and the hex number).
