First post, by baerenwurm
Hi!
If I want to start an old fli animation with various DOS players following error occurs:
"Exit on error: PIT:timer 0 set to unsupported bcd mode"
Hi!
I get the same message when trying to play "The Scrol" (adventure game). A movie should be played when this error appears (after the first menu in game)
Edit:
Adding to the database:
"Gateway II: Homeworld"
_________________
heh
I was searching with "pit timer" and no surprise i didn't find that post cause it has a .jpg instead of text 😉
I also checked dosbox status:
PIT/TIMER 95% Correct support for all timer modes
So i guessed that it should have been supported 😀
