First post, by feylon
Hello,
I was able to install Albion within dosbox/winxp, when I try to start it then, the game claims I should insert the cdrom.
I have read about other games doing that, and appending -ioctl or -aspi to the mount options of the cdrom should fix that, unfortunately not in my case.
Anyone has an idea?
feylon
Reply 1 of 10, by Dark Knight ez
maybe giving the cdrom a label would do the trick.
mount d d:\ -t cdrom -label LABELNAME
where d is your cdrom-drive
and LABELNAME is the actual name of the CD.
of course, here you could try out combinations with ioctl and aspi as well.
... // bda. very bda!
... // but only if you turn godo into csah.
Reply 2 of 10, by feylon
I had no success with adding a label too. What I noticed now is, when I add -aspi I get a failure message, although the cdrom can be accessed:
MSCDEX: Failure: Path not valid.
Drive D mounted as CDRom.
Perhaps I should have mentioned first, that even when starting Albion from WinXP the game claims about to insert the CDRom. I have 2 cd-drives and two virtual drives, and when I insert the cd in one, it claims to insert the cd in the other. I disabled all cd-drives expect one, and still had no success.
So perhaps its more a problem of WinXP than DosBox? (although I have read in the forum that other people using WinXP are able to play albion)
feylon
Reply 4 of 10, by feylon
Still no success 😒
I start DosBox with:
dosbox c:\dosboxhdc -c "MOUNT D H:\ -t cdrom -label ALBION -ioctl -aspi -usecd 0"
With all possible combinations of the last 3 switches.
Perhaps there is another method to describe the source-path of the cdrom in WinXP like /dev/xxx in linux?
feylon
Reply 6 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
as far as i know are -aspi -ioctl and -usecd 0 exclusive to another
the first one detected is the first one used.
Water flows down the stream
Reply 7 of 10, by Jiri
Neither in my case: Pandora Directive - no chance in 0.60? And probably also in this case: DSA2 (realms of arcania 2 - german) . Maybe no command can help you at this moment.
Reply 9 of 10, by cachaito
Hi! I had the same problem and I've done this: mounted iso with the game as disc D:\ (on disk C:\ i've installed the game) and it works!
Previously if I've used other discs names like E:\ or F:\ and the game was installed on C:\ Albion game did'nt want to work 🙁
Reply 10 of 10, by IIGS_User
Magic on drive C:? Most games requires to be installed there and don't accept other drive letters. 🙁
Klimawandel.
