First post, by Vince.Bloodworks
- Newbie
Hi folks,
first off I searched the internet for quite a while now, but couldn't find anything close to my problem.
Maybe I haven't searched hard enough, so if you read about this problem earlier, I'd really appreciate a link to the related post. 😊
I started to play DOOM/DOOM2 again some days ago. To make things a bit funnier, I started the game with the parameter -fast. Game starts, everything is fine. Because the game is a bit harder than usual, I save more often. ^^
Now the problem: Whenever I load my saved game(in game), on the first monster alert, dosbox freezes!
I have to close dosbox and restart it. Then I start the game again, using
DOOM.EXE -fast -loadgame 0
Everything runs fine, until the moment I have to reload my last savegame.
Has everyone encountered the same problem?
I tried this so far:
-Changed the output method(tested every method)
-Set aspect on/off(usually it's on)
The core is always=auto, the memsize=32, the machine type=svga_s3
I tried dosbox versions 0.73, 0.74, Hal's MB5 and MB6. The result is always the same.
Maybe I test it again later, using other machine types, but I don't think the solution lies there 😜
I hope you can help me with this. Thank you in advance 😀
