First post, by The_Ultra-Mind
As far as I can tell, the only way to do that is to play w/the cycles, but it doesn't seem to work that way. I'm playing Ultima IV, for instance, and the animations are way too fast at the default 6000. If I bring the cycles down to the several 100s, then everything visual seems to flow close to the correct pace, but then some sounds (and not others) take way too long. I've also tried setting core=simple, but that doesn't seem to make a difference. Is there something else I should be tweaking?
I'm running DB 0.74 in Ubuntu 14.04 64-bit on a AMD Phenom(tm) II X4 955 Processor × 4 and I'm using the proprietary driver for my GeForce GTS 250.
