First post, by Seraphim
Hi there!
Everytime i try to start the game "Vision" in DOSBox it stops on a blank screen.
In the second Window appears a Message:
Warning: file creation failed: e:\GAMES\VISION\CON
The Directory CON dosn't exist, but im unable to create a directory named CON. Not in DOSBox, not in Windows.
My System is an AMD XP 2500+ with WinXP Pro.
It seemed that Windows is unable to create this Directory.
Is it only a bug, or are there other ways to start this game in DOSBox?
If i start this game normaly under WinXP the game starts normaly, but there other things in this game won't work under WinXP.
Greetings
Seraphim
Reply 1 of 1, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
CON is a speciall DOS device (console). No file or directory can have this name.
It seems that the game tries to access CON device (not implemented in DOSBOX).
Mirek
