First post, by Grzemson
Hello,
I have an problem with my dosbox svn daum . I have installed in dosbox windows 98 second edition and dosbox emulate 3dfx voodooo card, but i have problem when i playing games, I have very low fps, for example : need for speed II se - 7 to 10 max fps, colin mcrae rally 2.0 - 4 to 6 max fps . It is because my emulated procesor in dosbox is 70 mhz, but most games colin2, nfs2,3 must be 233 mhz processor. I don't know what i must do.
My config file in dosbox.conf :
fullscreen=false
fulldouble=false
fullresolution=desktop
windowresolution=original
output=direct3d
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-SVN-Daum.map
pixelshader=none
usescancodes=false
overscan=0
logfile=
vga=true
vgagfx=true
vgamisc=true
int10=true
sblaster=true
dma_control=true
fpu=true
cpu=true
paging=true
fcb=true
files=true
ioctl=true
exec=true
dosmisc=true
pit=true
keyboard=true
pic=true
mouse=true
bios=true
gui=true
misc=true
io=true
pci=true
sst=true
language=
machine=svga_s3
vmemsize=8
vmemsizekb=0
captures=capture
mainline compatible mapping=true
mainline compatible bios mapping=true
adapter rom is ram=false
shell environment size=0
private area size=32768
a20=fast
isa bus clock=std8.3
pci bus clock=std33.3
rom bios allocation max=0
rom bios minimum size=0
memsize=256
memsizekb=0
dos mem limit=0
isa memory hole at 512kb=false
memalias=0
vga bios size override=0
video bios dont duplicate cga first half rom font=false
video bios always offer 14-pixel high rom font=true
video bios always offer 16-pixel high rom font=true
video bios enable cga second half rom font=true
forcerate=
sierra ramdac=true
sierra ramdac lock 565=false
page flip debug line=false
vertical retrace poll debug line=false
cgasnow=true
allow port 92 reset=true
enable port 92=true
enable 1st dma controller=true
enable 2nd dma controller=true
allow dma address decrement=true
enable dma extra page registers=true
dma page registers write-only=false
enable slave pic=true
enable pc nmi mask=true
rom bios 8x8 CGA font=true
rom bios video parameter table=true
allow more than 640kb base memory=false
vesa lfb base scanline adjust=0
allow hpel effects=false
allow hretrace effects=false
hretrace effect weight=4.00
vesa vbe 1.2 modes are 32bpp=true
allow low resolution vesa modes=true
allow 32bpp vesa modes=true
allow 24bpp vesa modes=true
allow 16bpp vesa modes=true
allow 15bpp vesa modes=true
allow 8bpp vesa modes=true
allow 4bpp vesa modes=true
allow tty vesa modes=true
enable vga resize delay=false
resize only on vga active display width increase=false
enable pci bus=true
pit hack=
frameskip=0
aspect=false
linewise=false
char9=false
doublescan=false
scaler=hardware2x
autofit=true
[vsync]
# vsyncmode: Synchronize vsync timing to the host display. Requires calibration within dosbox.
# Possible values: off, on, force, host.
# vsyncrate: Vsync rate used if vsync is enabled. Ignored if vsyncmode is set to host (win32).
# Possible values:.
vsyncmode=off
vsyncrate=75
[cpu]
core=dynamic
enable msr=true
ignore undefined msr=false
dynamic core cache block size=32
cputype=pentium
cycles=max
cycleup=500
cycledown=20
non-recursive page fault=false
ignore opcode 63=true
apmbios=false
apmbios allow realmode=true
apmbios allow 16-bit protected mode=true
apmbios allow 32-bit protected mode=true
integration device=false
isapnpbios=false
realbig16=false
[keyboard]
# aux: Enable emulation of the 8042 auxiliary port. PS/2 mouse emulation requires this to be enabled.
# You should enable this if you will be running Windows ME or any other OS that does not use the BIOS to receive mouse events.
# allow output port reset: If set (default), allow the application to reset the CPU through the keyboard controller.
# This option is required to allow Windows ME to reboot properly, whereas Windows 9x and earlier
# will reboot without this option using INT 19h
# auxdevice: Type of PS/2 mouse attached to the AUX port
# Possible values: none, 2button, 3button, intellimouse, intellimouse45.
aux=false
allow output port reset=true
auxdevice=intellimouse
[pci]
# voodoo: Enable VOODOO support.
# Possible values: false, software, opengl, auto.
# voodoomem: Specify VOODOO card memory size.
# 'standard' 4MB card (2MB front buffer + 1x2MB texture unit)
# 'max' 12MB card (4MB front buffer + 2x4MB texture units)
# Possible values: standard, max.
voodoo=opengl
voodoomem=max
[mixer]
# nosound: Enable silent mode, sound is still emulated though.
# swapstereo: Swaps the left and right stereo channels.
# rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.
# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
# blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.
# Possible values: 1024, 2048, 4096, 8192, 512, 256.
# prebuffer: How many milliseconds of data to keep on top of the blocksize.
nosound=false
swapstereo=false
rate=44100
blocksize=1024
prebuffer=20
[midi]
# mpu401: Type of MPU-401 to emulate.
# Possible values: intelligent, uart, none.
# mididevice: Device that will receive the MIDI data from MPU-401.
# Possible values: default, win32, alsa, oss, coreaudio, coremidi, mt32, synth, timidity, none.
# midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use.
# or in the case of coreaudio, you can specify a soundfont here.
# When using a Roland MT-32 rev. 0 as midi output device, some games may require a delay in order to prevent 'buffer overflow' issues.
# In that case, add 'delaysysex', for example: midiconfig=2 delaysysex
# See the README/Manual for more details.
# mt32.reverse.stereo: Reverse stereo channels for MT-32 output
# Possible values: off, on.
# mt32.verbose: MT-32 debug logging
# mt32.thread: MT-32 rendering in separate thread
# mt32.dac: MT-32 DAC input emulation mode
# Nice = 0 - default
# Produces samples at double the volume, without tricks.
# Higher quality than the real devices
# Pure = 1
# Produces samples that exactly match the bits output from the emulated LA32.
# Nicer overdrive characteristics than the DAC hacks (it simply clips samples within range)
# Much less likely to overdrive than any other mode.
# Half the volume of any of the other modes, meaning its volume relative to the reverb
# output when mixed together directly will sound wrong. So, reverb level must be lowered.
# Perfect for developers while debugging 😀
# GENERATION1 = 2
# Re-orders the LA32 output bits as in early generation MT-32s (according to Wikipedia).
# Bit order at DAC (where each number represents the original LA32 output bit number, and XX means the bit is always low):
# 15 13 12 11 10 09 08 07 06 05 04 03 02 01 00 XX
# GENERATION2 = 3
# Re-orders the LA32 output bits as in later geneerations (personally confirmed on my CM-32L - KG).
# Bit order at DAC (where each number represents the original LA32 output bit number):
# 15 13 12 11 10 09 08 07 06 05 04 03 02 01 00 14
# Possible values: 0, 1, 2, 3, auto.
# mt32.reverb.mode: MT-32 reverb mode
# mt32.reverb.time: MT-32 reverb decaying time
# Possible values: 0, 1, 2, 3, 4, 5, 6, 7.
# mt32.reverb.level: MT-32 reverb level
# mt32.partials: MT-32 max partials allowed (0-256)
mpu401=intelligent
mididevice=default
midiconfig=
mt32.reverse.stereo=off
mt32.verbose=off
mt32.thread=off
mt32.dac=auto
mt32.reverb.mode=auto
mt32.reverb.time=5
mt32.reverb.level=3
mt32.partials=32
[sblaster]
# sbtype: Type of Soundblaster to emulate. gb is Gameblaster.
# Possible values: sb1, sb2, sbpro1, sbpro2, sb16, sb16vibra, gb, none.
# sbbase: The IO address of the soundblaster.
# Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.
# irq: The IRQ number of the soundblaster. Set to -1 to start DOSBox with the IRQ unassigned
# Possible values: 7, 5, 3, 9, 10, 11, 12.
# dma: The DMA number of the soundblaster. Set to -1 to start DOSBox with the IRQ unassigned
# Possible values: 1, 5, 0, 3, 6, 7.
# hdma: The High DMA number of the soundblaster. Set to -1 to start DOSBox with the IRQ unassigned
# sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.
# oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type.
# All OPL modes are Adlib-compatible, except for 'cms'. sbtype=none
# together with oplmode=cms will emulate a Gameblaster.
# Possible values: auto, cms, opl2, dualopl2, opl3, none, hardware, hardwaregb.
# adlib force timer overflow on detect: If set, Adlib/OPL emulation will signal 'overflow' on timers after 50 I/O reads.
# This is a temporary hack to work around timing bugs noted in DOSBox-X. Certain
# games (Wolfenstein 3D) poll the Adlib status port a fixed number of times assuming
# that the poll loop takes long enough for the Adlib timer to run out. If the game
# cannot reliably detect Adlib at higher cycles counts, but can reliably detect at
# lower cycles counts, set this option.
# NOTE: Technically this decreases emulation accuracy, however it also reflects the
# fact that DOSBox-X's I/O timing code needs some work to better match the
# slowness of the ISA bus per I/O read in consideration of DOS games. So this
# option is ON by default.
# oplemu: Provider for the OPL emulation. compat might provide better quality (see oplrate as well).
# Possible values: default, compat, fast.
# oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).
# Possible values: 44100, 49716, 48000, 32000, 22050, 16000, 11025, 8000.
# hardwarebase: base address of the real hardware soundblaster:
# 210,220,230,240,250,260,280
# force dsp auto-init: Treat all single-cycle DSP commands as auto-init to keep playback going.
# This option is a workaround for DOS games or demos that use single-cycle DSP playback commands and
# have problems with missing the Sound Blaster IRQ under load. Do not enable unless you need this workaround.
# Needed for:
# - Extreme "lunatic" demo (1993)
# force goldplay: Always render Sound Blaster output sample-at-a-time. Testing option. You probably don't want to enable this.
# goldplay: Enable goldplay emulation.
# goldplay stereo: Enable workaround for goldplay stereo playback. Many DOS demos using this technique
# don't seem to know they need to double the frequency when programming the DSP time constant for Pro stereo output.
# If stereo playback seems to have artifacts consider enabling this option. For accurate emulation of Sound Blaster
# hardware, disable this option.
# dsp require interrupt acknowledge: If set, the DSP will halt DMA playback until IRQ acknowledgement occurs even in auto-init mode (SB16 behavior).
# If clear, IRQ acknowledgement will have no effect on auto-init playback (SB Pro and earlier & clone behavior)
# If set to 'auto' then behavior is determined by sbtype= setting.
# This is a setting for hardware accuracy in emulation. If audio briefly plays then stops then your DOS game
# and it's not using IRQ (but using DMA), try setting this option to 'false'
# dsp write busy delay: Amount of time in nanoseconds the DSP chip signals 'busy' after writing to the DSP (port 2xCh). Set to -1 to use card-specific defaults.
# WARNING: Setting the value too high (above 20000ns) may have detrimental effects to DOS games that use IRQ 0 and DSP command 0x10 to play audio.
# Setting the value way too high (above 1000000ns) can cause significant lag in DOS games.
# blaster environment variable: Whether or not to set the BLASTER environment variable automatically at startup
# sample rate limits: If set (default), limit DSP sample rate to what real hardware is limited to
# instant direct dac: If set, direct DAC output commands are instantaneous. This option is intended as a quick fix for
# games or demos that play direct DAC music/sound from the IRQ 0 timer who a) write the DSP command
# and data without polling the DSP to ensure it's ready or b) can get locked into the IRQ 0 handler
# waiting for DSP status when instructed to play at or beyond the DSP's maximum direct DAC sample rate.
# This fix allows broken Sound Blaster code to work and should not be enabled unless necessary.
# stereo control with sbpro only: Default on. If set, Sound Blaster Pro stereo is not available when emulating sb16 or sb16vibra.
# If clear, sb16 emulation will honor the sbpro stereo bit. Note that Creative SB16 cards do not
# honor the stereo bit, and this option allows DOSBox emulate that fact. Accuracy setting.
# dsp busy cycle rate: Sound Blaster 16 DSP chips appear to go busy periodically at some high clock rate
# whether the DSP is actually doing anything for the system or not. This is an accuracy
# option for Sound Blaster emulation. If this option is nonzero, it will be interpreted
# as the busy cycle rate in Hz. If zero, busy cycle will not be emulated. If -1, sound
# blaster emulation will automatically choose a setting based on the sbtype= setting
# dsp busy cycle duty: If emulating SB16 busy cycle, this value (0 to 100) controls the duty cycle of the busy cycle.
# If this option is set to -1, Sound Blaster emulation will choose a value automatically according
# to sbtype=. If 0, busy cycle emulation is disabled.
# io port aliasing: If set, Sound Blaster ports alias by not decoding the LSB of the I/O port.
# This option only applies when sbtype is set to sb1 or sb2 (not SBPro or SB16).
# This is a hack for the Electromotive Force 'Internal Damage' demo which apparently
# relies on this behavior for Sound Blaster output and should be enabled for accuracy in emulation.
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
adlib force timer overflow on detect=true
oplemu=default
oplrate=44100
hardwarebase=220
force dsp auto-init=false
force goldplay=false
goldplay=false
goldplay stereo=true
dsp require interrupt acknowledge=auto
dsp write busy delay=-1
blaster environment variable=true
sample rate limits=true
instant direct dac=false
stereo control with sbpro only=true
dsp busy cycle rate=-1
dsp busy cycle duty=-1
io port aliasing=true
[gus]
# gus: Enable the Gravis Ultrasound emulation.
# gusrate: Sample rate of Ultrasound emulation.
# gusbase: The IO base address of the Gravis Ultrasound.
# Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
# gusirq: The IRQ number of the Gravis Ultrasound.
# Possible values: 5, 3, 7, 9, 10, 11, 12.
# gusdma: The DMA channel of the Gravis Ultrasound.
# Possible values: 3, 0, 1, 5, 6, 7.
# ultradir: Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASND
[innova]
# innova: Enable the Innovation SSI-2001 emulation.
# samplerate: Sample rate of Innovation SSI-2001 emulation
# sidbase: SID base port (typically 280h).
# quality: Set SID emulation quality level (0 to 3).
# Possible values: 0, 1, 2, 3.
innova=false
samplerate=22050
sidbase=280
quality=0
[speaker]
# pcspeaker: Enable PC-Speaker emulation.
# pcrate: Sample rate of the PC-Speaker sound generation.
# tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.
# Possible values: auto, on, off.
# tandyrate: Sample rate of the Tandy 3-Voice generation.
# disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).
# ps1audio: Enable PS1 audio emulation.
# Possible values: on, off.
# ps1audiorate: Sample rate of the PS1 audio emulation.
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=false
ps1audio=off
ps1audiorate=22050
[joystick]
# joysticktype: Type of joystick to emulate: auto (default), none,
# 2axis (supports two joysticks),
# 4axis (supports one joystick, first joystick used),
# 4axis_2 (supports one joystick, second joystick used),
# fcs (Thrustmaster), ch (CH Flightstick).
# none disables joystick emulation.
# auto chooses emulation depending on real joystick(s).
# (Remember to reset dosbox's mapperfile if you saved it earlier)
# Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
# timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).
# autofire: continuously fires as long as you keep the button pressed.
# swap34: swap the 3rd and the 4th axis. can be useful for certain joysticks.
# buttonwrap: enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
# serial1: set type of device connected to com port.
# Can be disabled, dummy, modem, nullmodem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameter for all types is irq (optional).
# for directserial: realport (required), rxdelay (optional).
# (realport:COM1 realport:ttyS0).
# for modem: listenport (optional).
# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
# transparent, port, inhsocket (all optional).
# Example: serial1=modem listenport:5000
# Possible values: dummy, disabled, modem, nullmodem, serialmouse, directserial.
# serial2: see serial1
# serial3: see serial1
# serial4: see serial1
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[printer]
# printer: Enable printer emulation.
# dpi: Resolution of printer (default 360).
# width: Width of paper in 1/10 inch (default 85 = 8.5'').
# height: Height of paper in 1/10 inch (default 110 = 11.0'').
# printoutput: Output method for finished pages:
# png : Creates PNG images (default)
# ps : Creates Postscript
# bmp : Creates BMP images (very huge files, not recommend)
# printer : Send to an actual printer (Print dialog will appear)
# multipage: Adds all pages to one Postscript file or printer job until CTRL-F2 is pressed.
# docpath: The path where the output files are stored.
# timeout: (in milliseconds) if nonzero: the time the page will
# be ejected automatically after when no more data
# arrives at the printer.
printer=true
dpi=360
width=85
height=110
printoutput=png
multipage=false
docpath=.
timeout=0
[parallel]
# parallel1: parallel1-3 -- set type of device connected to lpt port.
# Can be:
# reallpt (direct parallel port passthrough),
# file (records data to a file or passes it to a device),
# printer (virtual dot-matrix printer, see [printer] section)
# parameter:value.
# for reallpt:
# Windows:
# realbase (the base address of your real parallel port).
# Default: 378
# ecpbase (base address of the ECP registers, optional).
# Linux: realport (the parallel port device i.e. /dev/parport0).
# for file:
# dev:<devname> (i.e. dev:lpt1) to forward data to a device,
# or append:<file> appends data to the specified file.
# Without the above parameters data is written to files in the capture dir.
# Additional parameters: timeout:<milliseconds> = how long to wait before
# closing the file on inactivity (default:500), addFF to add a formfeed when
# closing, addLF to add a linefeed if the app doesn't, cp:<codepage number>
# to perform codepage translation, i.e. cp:437
# for printer:
# printer still has it's own configuration section above.
# parallel2: see parallel1
# parallel3: see parallel1
# dongle: Enable dongle
parallel1=disabled
parallel2=disabled
parallel3=disabled
dongle=false
[glide]
# glide: Enable glide emulation: true,false,emu.
# lfb: LFB access: full,full_noaux,read,read_noaux,write,write_noaux,none.
# OpenGlide does not support locking aux buffer, please use _noaux modes.
# splash: Show 3dfx splash screen (requires 3dfxSpl2.dll).
glide=true
lfb=full
splash=true
[dos]
# xms: Enable XMS support.
# enable a20 on windows init: If set, DOSBox will enable the A20 gate when Windows 3.1/9x broadcasts the INIT message
# at startup. Windows 3.1 appears to make assumptions at some key points on startup about
# A20 that don't quite hold up and cause Windows 3.1 to crash when you set A20 emulation
# to a20=mask as opposed to a20=fast. This option is enabled by default.
# zero memory on xms memory allocation: If set, memory returned by XMS allocation call is zeroed first. This is NOT what
# DOS actually does, but if set, can help certain DOS games and demos cope with problems
# related to uninitialized variables in extended memory. When enabled this option may
# incur a slight to moderate performance penalty.
# ems: Enable EMS support. The default (=true) provides the best
# compatibility but certain applications may run better with
# other choices, or require EMS support to be disabled (=false)
# to work at all.
# Possible values: true, emsboard, emm386, false.
# zero memory on ems memory allocation: If set, memory returned by EMS allocation call is zeroed first. This is NOT what
# related to uninitialized variables in expanded memory. When enabled this option may
# ems system handle memory size: Amount of memory associated with system handle, in KB
# umb: Enable UMB support.
# umb start: UMB region starting segment
# umb end: UMB region last segment
# kernel allocation in umb: If set, dynamic kernel allocation=1, and private area in umb=1, all kernel structures will be allocated from the private area in UMB.
# If you intend to run Windows 3.1 in DOSBox, you must set this option to false else Windows 3.1 will not start.
# dynamic kernel allocation: If set, DOS kernel structures are allocated dynamically. If clear, DOS kernel structures are fixed at specific segments (mainline DOSBox behavior)
# keep umb on boot: If emulating UMBs, keep the UMB around after boot (Mainline DOSBox behavior). If clear, UMB is unmapped when you boot an operating system.
# keep private area on boot: If set, keep the DOSBox private area around after boot (Mainline DOSBox behavior). If clear, unmap and discard the private area when you boot an operating system.
# private area in umb: If set, keep private DOS segment in upper memory block, usually segment 0xC800 (Mainline DOSBox behavior)
# If clear, place private DOS segment at the base of system memory (just below the MCB)
# automount: Enable automatic mount.
# int33: Enable INT 33H (mouse) support.
# int 13 extensions: Enable INT 13h extensions (functions 0x40-0x48). You will need this enabled if the virtual hard drive image is 8.4GB or larger.
# biosps2: Emulate BIOS INT 15h PS/2 mouse services
# Note that some OS's like Microsoft Windows neither use INT 33h nor
# probe the AUX port directly and depend on this BIOS interface exclusively
# for PS/2 mouse support. In other cases there is no harm in leaving this enabled
# int15 mouse callback does not preserve registers: Set to true if the guest OS or DOS program assigns an INT 15h mouse callback,
# but does not properly preserve CPU registers. Diagnostic function only (default off).
# keyboardlayout: Language code of the keyboard layout (or none).
# dbcs: Enable DBCS table.
# CAUTION: Some software will crash without the DBCS table, including the Open Watcom installer.
# filenamechar: Enable filename char table
# collating and uppercase: Enable collating and uppercase table
# files: Number of file handles available to DOS programs. (equivalent to "files=" in config.sys)
# con device use int 16h to detect keyboard input: If set, use INT 16h to detect keyboard input (MS-DOS 6.22 behavior). If clear, detect keyboard input by
# peeking into the BIOS keyboard buffer (Mainline DOSBox behavior). You will need to set this
# option for programs that hook INT 16h to handle keyboard input ahead of the DOS console.
# Microsoft Scandisk needs this option to respond to keyboard input correctly.
# zero memory on int 21h memory allocation: If set, memory returned by the INT 21h allocation call is zeroed first. This is NOT what
# related to uninitialized variables in the data or stack segment. If you intend to run a
# game or demo known to have this problem (Second Unreal, for example), set to true, else
# set to false. When enabled this option may incur a slight to moderate performance penalty.
xms=true
enable a20 on windows init=true
zero memory on xms memory allocation=false
ems=true
zero memory on ems memory allocation=false
ems system handle memory size=384
umb=true
umb start=0
umb end=0
kernel allocation in umb=false
dynamic kernel allocation=false
keep umb on boot=false
keep private area on boot=false
private area in umb=true
automount=true
int33=true
int 13 extensions=true
biosps2=true
int15 mouse callback does not preserve registers=false
keyboardlayout=auto
dbcs=true
filenamechar=true
collating and uppercase=true
files=127
con device use int 16h to detect keyboard input=true
zero memory on int 21h memory allocation=false
[ipx]
# ipx: Enable ipx over UDP/IP emulation.
ipx=false
[ne2000]
# ne2000: Enable Ethernet passthrough. Requires [Win]Pcap.
# nicbase: The base address of the NE2000 board.
# nicirq: The interrupt it uses. Note serial2 uses IRQ3 as default.
# macaddr: The physical address the emulator will use on your network.
# If you have multiple DOSBoxes running on your network,
# this has to be changed for each. AC:DE:48 is an address range reserved for
# private use, so modify the last three number blocks.
# I.e. AC:DE:48:88:99:AB.
# realnic: Specifies which of your network interfaces is used.
# Write 'list' here to see the list of devices in the
# Status Window. Then make your choice and put either the
# interface number (2 or something) or a part of your adapters
# name, e.g. VIA here.
ne2000=true
nicbase=300
nicirq=3
macaddr=AC:DE:48:88:99:AA
realnic=list
[fdc, primary]
# enable: Enable floppy controller interface
# pnp: List floppy controller in ISA PnP BIOS enumeration
# irq: IRQ used by floppy controller. Set to 0 for default.
# WARNING: Setting the IRQ to non-standard values will not work unless the guest OS is using the ISA PnP BIOS to detect the floppy controller.
# Setting the IRQ to one already occupied by another device or IDE controller will trigger "resource conflict" errors in Windows 95.
# Normally, floppy controllers use IRQ 6.
# io: Base I/O port for floppy controller. Set to 0 for default.
# WARNING: Setting the I/O port to non-standard values will not work unless the guest OS is using the ISA PnP BIOS to detect the IDE controller.
# Standard I/O ports are 3F0 and 370.
# dma: DMA channel for floppy controller. Set to -1 for default.
# WARNING: Setting the DMA channel to non-standard values will not work unless the guest OS is using the ISA PnP BIOS to detect the IDE controller.
# Standard DMA channel is 2.
# int13fakev86io: If set, and int13fakeio is set, certain INT 13h commands will
# cause floppy emulation to issue fake CPU I/O traps (GPF) in
# virtual 8086 mode and a fake IRQ signal. you must enable this option
# if you want 32-bit floppy access in Windows 95 to work with DOSBox.
# instant mode: If set, all floppy operations are 'instantaneous', they are carried
# out without any delay. Real hardware of course has motor, command
# and data I/O delays and so this option is off by default for realistic
# emulation.
# auto-attach to int 13h: If set, DOSBox-X will automatically attach a disk image as being
# inserted into a floppy drive attached to the controller when imgmount is used
# to mount a disk image to drive 0/1 or A/B. If not set, you must specify
# the -fdc option to imgmount to attach drive A/B to the floppy controller
# manually. You must use the -fdc option regardless if loading floppies into
# drives attached to any other FDC than the primary controller
# mode: Floppy controller mode. What the controller acts like.
# ps2 PS/2 mode (most common)
# ps2_model30 PS/2 model 30
# at AT mode
# xt PC/XT mode
# chip: Floppy controller chipset
# 82077aa Intel 82077AA chipset
# 82072 Intel 82072 chipset
# nec_uPD765 NEC uPD765 chipset
# none No chipset (For PC/XT mode)
enable=false
pnp=true
irq=0
io=0
dma=-1
int13fakev86io=false
instant mode=false
auto-attach to int 13h=true
mode=ps2
chip=82077aa
[fdc, secondary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, tertiary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, quaternary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, quinternary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, sexternary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, septernary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[fdc, octernary]
enable=false
pnp=true
irq=0
io=0
dma=-1
instant mode=false
mode=ps2
chip=82077aa
[ide, primary]
# enable: Enable IDE interface
# pnp: List IDE device in ISA PnP BIOS enumeration
# irq: Alternate I/O port for IDE controller (alt status, etc). Set to 0 for default.
# For best compatability set this value to io+0x206, for example, io=1F0 altio=3F6.
# The primary IDE controller will not claim port 3F7 if the primary floppy controller is enabled due to I/O port overlap in the 3F0-3F7 range.
# int13fakeio: If set, force IDE state change on certain INT 13h commands.
# IDE registers will be changed as if BIOS had carried out the action.
# If you are running Windows 3.11 or Windows 3.11 Windows for Workgroups
# you must enable this option (and use -reservecyl 1) if you want 32-bit
# disk access to work correctly in DOSBox.
# cause IDE emulation to issue fake CPU I/O traps (GPF) in
# if you want 32-bit disk access in Windows 95 to work with DOSBox.
# enable pio32: If set, 32-bit I/O reads and writes are handled directly (much like PCI IDE implementations)
# If clear, 32-bit I/O will be handled as if two 16-bit I/O (much like ISA IDE implementations)
# ignore pio32: If 32-bit I/O is enabled, attempts to read/write 32-bit I/O will be ignored entirely.
# In this way, you can have DOSBox emulate one of the strange quirks of 1995-1997 era
# laptop hardware
# cd-rom spinup time: Emulated CD-ROM time in ms to spin up if CD is stationary.
# Set to 0 to use controller or CD-ROM drive-specific default.
# cd-rom spindown timeout: Emulated CD-ROM time in ms that drive will spin down automatically when not in use
# cd-rom insertion delay: Emulated CD-ROM time in ms that drive will report "medium not present"
# to emulate the time it takes for someone to take out a CD and insert a new one when
# DOSBox is instructed to swap or change CDs.
# When running Windows 95 or higher a delay of 4000ms is recommended to ensure that
# auto-insert notification triggers properly.
enable=true
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
cd-rom spinup time=0
cd-rom spindown timeout=0
cd-rom insertion delay=0
[ide, secondary]
enable=true
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, tertiary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, quaternary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, quinternary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, sexternary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, septernary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[ide, octernary]
enable=false
pnp=true
irq=0
io=0
altio=0
int13fakeio=false
enable pio32=false
ignore pio32=false
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
Reply 1 of 4, by F2bnp
What are the specs of the PC you're running this on?
Keep in mind, Win98SE and 3Dfx Emulation in DOSBox is still fairly experimental and trying to run 1997-1999 games on it can be quite a stretch. PCEm might be a more viable option here, although I doubt Colin McRae Rally 2 will run properly on anything emulated.
Reply 2 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Official Dosbox does support neither Windows 9x nor 3dfx emulation. Please ask the author of that version for help.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 4, by Grzemson
I'm using PC of specs : Intel Core i5 4690 3.50 ghz, 8gb ram, Nvidia geforce gtx770 2gb, windows 7 ultimate 64bit in my host pc.
I watched some guy played games (colin 2 ) and they are running nice. Link for this film : https://www.youtube.com/watch?v=TBke_ZNBpZg (15:30 colin2) .
Reply 4 of 4, by F2bnp
Yes, we had a thread about that. Interlace is also a member here and he had mixed results in a lot of cases. Some games seem to run fine only to have some insane drops in framerate. Perhaps you could try mimicking his config file?
