First post, by sndwv
If I compare Phil's excellent recording of Gateway 2: Homeworld on actual hardware:
https://www.youtube.com/watch?v=yHocdA542UI
to my attached recording on my actual MT-32 (old type), but via DOSBox, it seems mine is playing a bit too slow, most noticeable on the timpani rolls. Phil's recording sounds 'right' to me, and is how I remember it from childhood.
I know cycle settings among others have an effect on this, but as of yet I have not been able to get it 'right' (just this, or completely broken). Does anyone know what's going on here?
gw2.wma
1.02 MiB
109 downloads
Gateway 2 intro, MT-32 old, DOSBox SVN r3950
PS - Eric the Unready (same engine) seems 'off' to me in the same way, but I have no actual hardware recording to compare with, just one video I found that sounds exactly the same as mine, but could very well have been recorded on DOSBox as well.
Reply 1 of 35, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The Legend adventures use the MPU-401 Conductor, so if you're compiling SVN you might try reducing the MPU401_TIMECONSTANT define in mpu401.cpp to see if that makes the music speed more like what you think it should be.
Reply 2 of 35, by sndwv
That would be my first time compiling from SVN (or anything at all), but I would not mind looking in to this in the weekend. 😀 Would that mean all games using the conductor would be slightly off, and is there even an objectively 'correct' speed? I assume the current value wasn't picked arbitrarily? Or does it vary depending on host system?
Reply 3 of 35, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I don't think the timing was chosen by ear, it's based on beats-per-minute and tempo commands to the MPU. I doubt the time constant is wrong; changing it is just an easy way to check if the music speed is related to the conductor timing.
Reply 4 of 35, by sndwv
Allrighty, found a seemingly good tutorial for compiling on Windows; I'll have a go at it later today or tomorrow and report back.
I found the line:
#define MPU401_TIMECONSTANT (60000000/1000.0f)
What should I change it to to make a sensible but audible difference? 10% faster or so?
Reply 5 of 35, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I checked and the game is indeed using the MPU Conductor. It sets 123 BPM for the intro song, and overriding that to ~135 BPM seem to be more like the speed in phil's video. However, I don't know why there would be a discrepancy. Maybe check if the music speed in the first Gateway game seems correct to you.
Reply 6 of 35, by sndwv
Thanks. Just did, this is Phil's recording:
https://www.youtube.com/watch?v=c3NhTcpWcf4
and here is mine:
gw.wma
1.49 MiB
105 downloads
Gateway 1, MT-32 (old), DOSBox SVN r3950
The difference is less audible here, but Phil's music starts ~6s into the video, and when I stopped my recording at 2:08 they were almost synched up. That means my recording is ~5% slower than Phil's.
edit: and this is the Eric the Unready sample I found: https://www.youtube.com/watch?v=7NIx7Z9Y5vc (sounds the same here). No comparison available for this one, but it sounds off to my ear, does not 'flow' correctly. Same engine, so safe to assume the same issue.
Reply 7 of 35, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The HOME_001.MUS file is a library of song files that can be extracted using a ripping tool that understands standard MIDI format. I found that the 21st song file is the game's MT-32 intro music, and playing that in a Windows MIDI player shows 123 BPM, so the game does not seem to be using that in error, and the music does indeed play a bit faster than in DOSBox.
Srecko might have an idea where to start looking for a Conductor timing issue, but haven't seen him around for awhile. I guess I'll fiddle with the timebase and interrupt delay stuff to see if anything looks promising.
Reply 8 of 35, by sndwv
Great, thanks for taking a look. If there's anything I can do to help, let me know.
By the way: which tool is that? Would like to take a look at that, out of curiosity. I assume it's not allowed to attach the MIDI file?
Reply 10 of 35, by sndwv
Awesome. For completeness sake I've attached recordings of the extracted .MIDs, played using GSPLAY in the exact same DOSBox environment the games were run in. GSPLAY plays them back at their correct (faster) speeds, same for Eric the Unready, which I can confirm has the same issue of being too slow when played by the game engine.
63.25 KiB
    eric.wma
    1.43 MiB
    90 downloads
    gw2.wma
    1.39 MiB
    90 downloads
    gw.wma
    1.44 MiB
    83 downloads
Reply 12 of 35, by ripsaw8080
Rank DOSBox Author
DOSBox Author
After some analysis of the Legend MPU playing code, I made a workaround program that corrects the tempo issue in my tests. Gateway has an additional but apparently related issue where it doesn't play more musical selections after the first one during the game, and as a bonus this new workaround does an even better job of fixing that issue than the previous one I made.
I've tested the attached TSR program with Gateway, Gateway 2, and Eric the Unready with ~10000 cycles in DOSBox SVN, and the MT-32 music tempo sounds right to me. I recommend a vanilla SVN build because the workaround may be less effective elsewhere.
The issue appears to be a somewhat complicated interaction between IRQ 9 and IRQ 0, so may be in the MPU and/or PIC emulations, but I have not yet identified the specific problem.
    legmpu.zip
    274 Bytes
    147 downloads
    Password: vogons
Reply 13 of 35, by sndwv
Fantastic! Tried it with SVN r4000 at 20000 cycles (happens to be what I set it to last) and it sounded perfectly fine/correct to me.
Great workaround for now; I can finally play these games again, but if there's any further testing to be done for a DOSBox fix I can help out with, let me know!
Reply 14 of 35, by keropi
ripsaw8080 is that fix also applicable to real hardware? Gateway stops playing in-game scores after the first one on real hardware if there is some IRQ sharing business (in lack of better description) - in my case I had to disable ACPI to fix that issue (since apparently ACPI is hardwired to IRQ9). The game's driver is really picky and sensitive I never really knew I had this issue until someone mentioned it here and tested on my p1/MPU401AT system.
btw stupid chrome detects your fix as malicious , total annoying BS from chrome
Reply 15 of 35, by Qbix
Rank DOSBox Author
DOSBox Author
hmm if chrome does that, than maybe zip it with password or so.
Otherwise vogons will get flagged for hosting malware.
Water flows down the stream
Reply 16 of 35, by ripsaw8080
Rank DOSBox Author
DOSBox Author
False positives happen, I guess. Reposted the attachment with a password; I hope it's enough to shut out Chrome's scanning.
@keropi: The workaround is hardcoded for an MPU using IRQ 9, but it's unlikely to be useful in your case. It might help with SoftMPU, which uses the DOSBox MPU emulation.
Reply 17 of 35, by KainXVIII
Yeah, i also noticed that tempo is really off with dosbox and munt (TSR program fixed that)
Too bad that digitized sound effects crackles so much in old legend games..(ie Companions of Xanth)
Reply 18 of 35, by keropi
@ripsaw8080
I see, thanks for the explanation. New zip is fine, chrome does not complain 😀
