First post, by basti007
The sound sampling of Time Paradox - Flair Software (1996) is wrong. Has anyone an idea how to fix it? I already tried to reduce sampling rate in the dobox config file, but nothing helped. the sampling is alwas doubled (peopel speak much to fast).
Reply 1 of 8, by Hazekel
I have a similar problem. No audio in mine, but the text dialogue speeds by too fast to read and there do not appear to be any options to slow it down.
Reply 2 of 8, by red_avatar
I'm trying this game too, at least a hacked version, and either the text stays on screen for ages, or the text flies by.
Reply 3 of 8, by Hazekel
Has anyone ever solved this problem?
Reply 4 of 8, by red_avatar
The original CD works perfectly for me now - maybe a bad rip you have ?
Reply 5 of 8, by Hendrik78
Does somebody know how to run this game? If I start it I get an installation error. I use an image in deamon tools as drive H: I use dosbox game launcher.
Make it so!
Reply 6 of 8, by red_avatar
The version I had was broken - the guy I bought it from was selling re-made copies. Basically, the disc contained an error. Using the ripped version I downloaded, I managed to create a fully working CD version. Maybe you can try that.
Reply 7 of 8, by Hendrik78
Well that worked. But now the game is choppy and the sound is hanging.
Make it so!
Reply 8 of 8, by Hendrik78
fixed it. I set the cycles back.
Make it so!
