First post, by Hotte76
Hi,
i´m running Dosbox and Windows 3.11 on my Raspberry Pi (RetroPie) for retro-gaming.
A few days ago i bought You don´t know Jack 2 and 3 from ebay.
You don´t know Jack 2 runs fine, but 3 doesn´t. 😵
If you look on the CD Cover it is said: Windows 3.x (see attached picture), but there is no installation file for it.
All executable files (setup.exe e.g) end with an Win32 error message.
Even in mobygames it is listed with win 3.x....
http://www.mobygames.com/search/quick?q=you+dont+know+jack+3
Does anyone know anything? Is it a printing error? Were there patches for running it in Windows 3.x?
Or an special Win 3.x version? But why is there win3.x on the case?
Thanks for any hints 😀
    110.75 KiB
    CDCover
Reply 1 of 15, by Jorpho
That would suggest you need "Win32s", which Microsoft released near the end of Win 3.x support.
https://en.wikipedia.org/wiki/Win32s
I would expect that it would be included on the CD somewhere if it was required.
Reply 2 of 15, by Scali
Yup, some early Win95 games could also be run with Win32s, and some of them even made use of 'WinG', which can be seen as the predecessor to DirectX: https://en.wikipedia.org/wiki/WinG
Both can be installed on top of Windows 3.x, perhaps that makes Jack 3 work.
Reply 3 of 15, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Yes, try Win32s, you can get it from the Windows 3.x guide.
(And moving this to the Dosbox forums)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 15, by Hotte76
Hi, and thanks for the replys.
To be more precise, i get the following error:
Win32S Error - D:\install\setup.exe invalid format
followed by another window:
Cannot run program. Unexspected error 21.
I tried now the following:
- Installed Win32s -> Still the same error (checked it, Freecell is working)
- Installed WinG -> Still the same error (works definitly, because Civilization II is running).
I then found this post, which is about the same error, but even the cpu hint didn´t work.
Win32s error
Any other ideas? 😀
Reply 6 of 15, by Hotte76
There are indeed more than one....
One is called "Install!" in the main folder of the CD (doesn´t work) and another one is in the INstall folder called "Setup.exe", which comes to the same result. I tried both executables and both did the same problem.
Reply 10 of 15, by Hotte76
No, of course not.
I get basicly the same error message but with the executable i tried.
So when i try setup.exe i get the error message with "setup.exe" but when i try "install" i get the error but of course with "install"
Reply 11 of 15, by Hotte76
Ok, i just received an answer if the gane was playable in win3.x from the american company who one designed the game:
Jackbox Games Support told me it´s maybe a printing error on the CD-ROM.....
Reply 12 of 15, by Jorpho
It seems to me much more likely that they're just guessing and have no idea how they would get a game from twenty years ago running in Windows 3.x.
That said, if http://stephan.win31.de/w32slist.htm is any indication, this probably isn't a DOSBox problem. I might guess that it would be possible to hack the .exe so that Win32s will accept it, but I would expect a lot more people would be doing that (and be writing guides accordingly) if that was feasible.
Maybe it's just a problem with the installer, so it will work if you install the game in Windows 95 and copy the files to your Windows 3.1 installation.
Reply 13 of 15, by Hotte76
Yes, i think so too.
I tried to copy an installed game, but the error remains....
So i decided to give up, and re-sell the game on Ebay.
It was a nice try, to get alle 3 YDKJ´s which would run on Win 3.x,
now i can play only 2 of them, which is ok for me... 😎
Thanks for all the help
Reply 14 of 15, by ripsaw8080
Rank DOSBox Author
DOSBox Author
FYI, "Unexpected error 21", or "DOS error 21" is a common problem with programs that use Win32s in DOSBox. Setting cputype=486_slow or cputype=pentium_slow in the conf will usually avoid such errors. However, it's not necessarily the only problem in the case of YDKJ3.
If the cdrom includes a Win32s installer, whether it is run automatically by the game installer or run manually, it strongly suggests that the game will work with Win32s; but either way it's not proof positive.
Reply 15 of 15, by Hotte76
The game is sold, case is closed.
I found a second hand re-buying site which payed me more than i paid for the game 😉
Sold some things there months ago, it was good. So i don´t have to mess around with ebay 😉
