First post, by danrevella
Hi!!
This french game "In Extremis" IMO is terrible, but it's really interest coz it has the ability to lock any debugger (Softice on real computer incluse) and also GameWizard32.
For me the GW situation is unaccetable, so I have write a patch to renforce GW and enabling it in this game, and also in other game who try to lock it.
I call this little program: GameWizardEnforcer..... 😉
I uplod it here with also the (shareware version) of GameWizard32.
How does it work?
GameWizard32 Enforcer by Danrevella Feb. 2017
GameWizard32 ver. 3.0a in 1995 was the better memory cheat program.
It also was able in saving/loading the state of the computer so you may reload it
at later time.
BTW there were some strong games who locked GW.
1) GW was unable in pop-up
2) GW was able in pop-up, but keyboard was locked and you had to reset computer
So here is the solution: Gwenf...... GameWizardEnforcer
Pre-requisite: you must have just installed GW in c:\gw
Installing:
supposing you have GW installed in c:\gw copy in that folder the files:
fi.exe
multigwx.exe
gwenf.bat
Utilizing:
case 1)
>c:
>cd c:\gw
>gwenf.bat
Now load your game and use the 'p' key to activate GW (you have to try many time.....)
case 2) using Quake 1 or Quake 2 as example
>c:
>cd c:\gw
>gwenf.bat 88
What is this '88' ??
88 is the Irq0 base in the game Quake.
How may You get this number who may be different for every game?
In this way:
be sure you have a ps2 mouse connected with his driver just loaded (ctmouse f.e.)
>c:
>cd c:\gw
>fi.exe
Now load your game and as soon as you press the right-button of your mouse, my program will try
to discover where Irq0 of the game is located.
Simply wait 30 sec.
If after this time the screen is still black, please press and release many time the space bar key.
In the right upper of the screen will appear somethingh like "T88", well 88 is the parameter you have
to supply in case 2) as I give you in example above.
AHHHHH!!!!!
Forget to tell you.......
fi.exe (FindIrq0) is able to locate the Irq0, but then your game will crash, and you'll have to
restart your computer, so please keep note of the 'TXX' displayed!!!!!!
GwEnforcer does work on real machine, dosbox, 86box, Pcem
If you need help, please write me here:
darthmaurizio@gmail.com
