First post, by vasom
I have problem with Clipper application ( using MS Windows 7 /32 bit , DOSBox, Clipper 5.2). When application is going to add record/records into a base
( with some calculations ) it performs obviously slow. What I should do to make application faster.Of course that application works well in DOS, Windows XP
enviroment .
