First post, by Terrapin
Hey Vogonites,
For a while now, I've been trying to set up an automated, no-cd DOSbox installation of Realms of the Haunting with custom .bat and .conf files for easy access and proper emulation.
I've accomplished all I've set out to do as far as that goes and Sound Blaster 16 works fine, but it just doesn't sound quite right. Or at least not how I remember it.
I've recently found out about Gravis Ulrasound emulation through DOSbox and have gotten it working in several other games. As for Realms though, I have been able to enable GUS via the included setup program, but upon opening the game (set to VESA 640x480), there is no MIDI music and sound is clicky, poppy, staggered, laggy, etc.
When playing the test music/sound in the setup program, the sounds play, but it's cut off a bit when it plays. I believe my conf file is properly configured for GUS emulation.
Is this normal with GUS and a game that relies heavily on graphics? Should I be using an SVN for driver compatibility maybe?
