First post, by Serious Callers Only
It's been a while, but i've been experimenting with my dosbox.conf files and i remembered.
Is 256 color mode somehow more compatible than the so called '64k' on the windows drivers with dosbox resolution change? I ask because, without 'fullresolution=original' (that also streches) on several win3.11 games .conf, and running windows 3.11 with 640x480 64k colors, the dosbox screen (and windows, and any game running) appear as a 'box' inside of a larger non-scaled fullscreen window (if fullscreen).
While if i use the 640x480 256 colors driver, my window is completely 'column boxed'.
I suspect this is a driver and nothing to do with dosbox right? Dosbox doesn't scale the image to fullscreen after windows boots, and my driver doesn't like the windows '64k' but is fine with '256', correct?
Reply 1 of 4, by leileilol
leileilol wrote:
- Dosbox doesn't scale up hi-color video modes
long live PCem
Reply 2 of 4, by Serious Callers Only
Uh, i kind of hate how this forum doesn't allow clicking quotes to check context. So it's dosbox not doing something instead of the drive not doing something. Would the 'pixel-perfect patch' output help?
Reply 3 of 4, by Jo22
Hmm. I'm using OpenGL output, fullresolution=desktop and I run Windows 3.1 in 256 colours (-> supports palette cycling) . Works fine for me.
Edit: Just checked again. Same here (Dosbox-r4023): 32k/64k colours won't give fullscreen/scaled.
Reply 4 of 4, by Serious Callers Only
That works on normal dosbox, yes. I'm writing about the 15/16 bit color modes that appear if you install the s3 drivers (called 32k and 64k on the menus).
