First post, by Beepzorz
I'm succesfully installed the game using a CD image, and it boots and plays fine, except the sound effects don't seem to play (though I'm not sure if there are supposed to be any for the things I'm doing) and voices cut off almost immediately after they begin (I can barely hear one syllable before it cuts off). The background music does play perfectly, however.
I've installed it using the default recommend settings (Soundblaster with IRQ 5 and IO address 220h). I re-installed it with the Adlib Library, but to no effect.
I've tried searching for topics where people had similar issues, but I can't seem to find any. Any idea on how to fix these issues? Thanks in advance.
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
IRQ 7 is what DOSBox uses for the SB by default.
Reply 2 of 2, by Beepzorz
It worked! The voices don't cut off anymore. Although I'm more annoyed than anything else, because I had already tried it with IRQ 7 at one point and the issue still persisted then.
Still, I should thank you, since you did make me try IRQ 7 again, so thanks.
