First post, by Guest
I am not getting any sound when I play Master of Magic. I am new to using DosBox myself. I was quite familiar with Dos back in the day but haven't used it in years...
Anyways, here are my system specs. My audio comes through the Asus motherboard.
AMD Athlon 2200 (Running around 1900 Mhz)
Asus A7V8X (Audio comes through this)
512 MB DDR 400
Running Windows 2000 5.00.2195 Service Pack 4
Any help would be greatly appreciated. The game runs fine, just no sound is coming through.
Reply 1 of 2, by oneirotekt
Make sure the soundcard is configured properly in MoM's sound setup utility (should be INSTALL.EXE in the game directory). If you're using the default DOSBox settings, it'll be something like Port 220, IRQ 7, DMA 1... if you've worked with DOS before you know the drill.
