First post, by tsukasu
I just intalled DOSBox today and I got it to play Space Quest 4 by running it off the CD (it wouldn't let me run it off the HD). Now when I try to save my game it won't let me it says the specified directory is full or some crap. I tried changing the directory but it won't work. Anyone know what to do?
Reply 3 of 8, by DosFreak
SQ4 works fine here. Read-only doesn't matter since when you create a new savegame it creates a new file which doesn't have read-only applied (obviously). Try checking permissions on the directory and using the latest CVS.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 4 of 8, by tsukasu
I'm not sure what you mean by checking permissions or CVS. I have the CD version and I installed it on the HD but when I usd DOSBox it said the file is a Windows file and wouldn't open it. So I set it to run off the CD and it works great but when I go to save it says the directory is full so I looked and it has it at D: (which is my CD-Rom) so I made a folder on my HD and I went to "Change Directory" in Save and I put in C:\Saved Games and it says it's not a valid Directory so Ijust put in C: and it says the directory is full. Any suggestions?
Reply 6 of 8, by DosFreak
Hmmm, C:\Saved Games is not a valid directory for Dos since you are using 11 character when you should just be using 8.
