First post, by KO23L
- Newbie
Hello,
I would like to discuss the DOSbox settings (config) for Golden Axe game (classic PC MS-DOS version).
Yesterday I have tried to run the game on actual latest DOSbox build 0.74-2 and Iam having some issues for which i could not find solution.
My spec:
Win 10 Home
Intel Core i5-9400F (2.9GHz, TB 4GHz)
16GB RAM DDR4 2666 Mhz
NVIDIA GeForce RTX 2070 8GB
I have started with clean dosbox install (default settings) and just tried to run the game, but I have found that the game suffers from some lets say slow-downs or tearing mainly when the enemies appears. The more enemies appear = the bigger the slow-down is.
I was trying to set the fixed core emulation (tried the 386 one) but this doesnt bring any results, then i was trying to set rendering from surface to opengl. The opengl settings came with minor improvement (now i was at least able to fight with Level 1 boss-pack and win - not being killed in "lag/freez") but still it is not running smoothely.
Does someone have any tips on what settings to tweak to make ideal config for this particular game? Should i focus more on tweaking the game cycles, or enable some frameskip to get the illusion of smooth run?
Thanks in advance to anyone who can give me some insights 😊 .
