First post, by Wrees
Hello.
I recently installed NHL 95 to the dosbox C drive from an ISO file that I mounted with IMGMOUNT. The installation went smoothly and I was able to play the game.
However, when I tried to play the game again Dosbox gives me this error:
Insufficient Disk Space free on 'C:'
Please free up at least 10 Kbytes of disk space
The command freesize is not fixing the problem. I have tried different values and still get the exact same error.
But if I input -freesize 0.30, for example, the error message says that I need 2 Kb instead of 10. (The value in freesize is in MB, I presume?)
