First post, by MrFlibble
So a while ago I found a demo of an unreleased RPG game called The Seventh Sword of Mendor on a coverdisk, and it works fine in DOSBox, but only if there is no sound. If I set it to use Sound Blaster or Sound Blaster Pro it freezes DOSBox right after the publisher's logo. loadfix did not help.
I packed and uploaded the demo here. You don't need to install it with INSTALL.BAT, INST.EXE is used to configure the sound device.
DOS Games Archive | Free open source games | RGB Classic Games
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Try the same workaround used for Charly the Clown shareware - no sound
Mendor doesn't need EMS, so in this case you can load JEMM with: JEMMEX NOEMS LOAD
You may or may not need a fixed amount of cycles as well; 10K-20K seems okay.
